bumpers
Old Jun 4, 2011 | 08:54 PM
pleasants9's Avatar
pleasants9
Default bumpers
So I am planning to repaint my 82 vette, I want to replace the bumpers that are on there now, the front one has a crack and the rear one looks poor. What type of bumpers would you recommend to replace them with? Fiberglass? polyurethane?
Old Jun 4, 2011 | 11:52 PM
RIJVETTES's Avatar
RIJVETTES
I have an 80, and replaced both front and rear bumpers a couple of years ago during a repaint. As you may know, the fiberglass is straight and maintains its shape better than the urethane- if you have no collisions. So if you drive your vette infrequently, or don't have much threat of a collision, then fiberglass is definitely the way to go, On the other hand, the urethane will be more forgiving in a minor collision.
With this said, and the fact that I want my vette to always look good, and drive it about 7000 miles a year in San Diego county, I have urethane in the front, and a nice straight, non-waivy rear bumper.
Old Jun 5, 2011 | 10:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The choice is up to you. All of the aftermarket fiberglass covers require individual fitting.
Old Jun 5, 2011 | 10:30 AM
Mark G's Avatar
Mark G
I think RIJVETTES summed it up pretty well.
Urethane - More like original, expect some minor waviness, good choice for original restoration. Better minor collision protection
TrueFlex fiberglass - Some give, no waves (don't make the mistake that it's a HUGE amount of flex).
Fiberglass - Most ridgid, no waves.
ALL will require fitting and sanding/filing, even the urethane bumper's (in my case). I started out with a TrueFlex front bumper, then I decided to shift gears and go with a urethane bumper because I was doing a restoration to original and figured I'd recoup my extra investment someday when I go to sell.
Mark G
Old Jun 5, 2011 | 01:09 PM
24695bob's Avatar
24695bob
I have replace both the front and rear bumpers on both my 76 and my 79 several times...
and have used urathare fiberglass and the True flex bumpers...
I NOW will only use only use TRUE FLEX in the future......they hold up better then Urethane (paint wise ) and flex enough that they will not crack..
ALL 3 types do require a "little" fitting to be done on you part...
Bob G
Old Jun 5, 2011 | 10:26 PM
Mark G's Avatar
Mark G
Bob,
Curious what paint problems did you have with the Urethane bumpers?
On mine, once I finished scuffing the raw urethane bumper, I sprayed an approved adhesion promoter (special solvent), to essentially 'gum-up' the outer layer of the urethane to promote a bond with my first layer of primer/sealer. Some guys skip this step due to the $40/qt of adhesion promoter. Doing so can can result in less adhesion and possibly peeling paint, a subject that has come up here before.
Mark G
Old Jun 5, 2011 | 11:28 PM
pleasants9's Avatar
pleasants9
yeah I am sanding the whole thing down, blending in the back bumper and leaving the front bumper as an extra piece so im not worried about he effort needed to shape them it was gonna be done either way, I was not aware of the TRUEFLEX bumpers, I am liking the sound of them, I am pretty sold on fiberglass for the bike I dont even want to witness the difference in paint fade on the urethane compared to the fiberglass body like i have with my present original bumper. Plus I definitly don't want wavy on my front bumper so I am town between fiberglass in the front or the TRUEFLEX. Where is the best place to buy them? Ecklers?
Old Jun 6, 2011 | 12:00 AM
onaqwst's Avatar
onaqwst
fiberglass ...... and not ecklers...
Old Jun 6, 2011 | 07:51 AM
24695bob's Avatar
24695bob
Originally Posted by Mark G
Bob,
Mark G
Mark....basically over time (years) the bumpers would fade enough that I could see the difference from the regular body.... which was painted at the same time...
Both cars were painted by a guy who specialized in Corvettes and has painted close to 100 Bloomington Gold cars... The true flex bumpers have not faded at all in over 10 years since I had installed them
Bob G.
Old Jun 8, 2011 | 08:48 PM
pleasants9's Avatar
pleasants9
so wheres the best place to get the bumpers?
To bumpers
