Whats the best way to upgrade stereo in C3
Navigator
Hi, I have a 1979 C3 and want to upgrade the stereo, I got one of those retro stereo's from Ecklers and wondered what the best method would be, it looks like the allen head panel screws are rounded on the dash but I can get behind the OEM radio from the side console panel but there is not enough space to back it out, the heater duct is in the way, however the new radio is half the size and would fit right in. I'm hoping some other people have done this and have some advice, Thanks Guys-JSP
Rick B.
1 Post
There are 2 screws above the gauges, one on each side and then you have to remove the carpet on the sides of the tranny tunnel so you can get to the 2 screws on the bottom from the inside. It is very easy to put in a new radio. Put some new 4X6 speakers in the dash and kick panels, a couple of new 6X9 in the rear and you will enjoy the new tunes. Amp helps also. Paul 74 is correct, just cosmetic.
Yellow arrows show where the six screws need to be removed from the bezel. You need to remove the center column side panels to access the two screws at the bottom corners that hold the bottom console bezel to the gauge bezel.
See article at http://www.californiastingrays.us/Ar...tts/Radio.html
one of the best upgrades i have done .the cd player i have has the usb port .no more cds.and a lot of music on the 4g.http://vettes.shutterfly.com/picture...res:albumId=48
Terry , that is nice! Where did you pick up the wooden shift ball? Thanx!
no amp yet .the sound upgrade was verry good .with just the kenwood head deck .polks in the front kenwood excelon in the rear .i may amp later .
I also have polk speakers in the headrests of my seats, so total I have the two dash speakers, 4 speakers in the headrests, and the 2 boston in the rear along with the sub in the rear. There are two amps in the jack compartment (hope I dont get a flat, but I got AAA)
Navigator
Hi Guys I want to Thank You all for the help, with "yellow 1980's" diagram I was all set and was able to get the gauge cluster out and the radio lifted out without a problem, of course after seeing "dmeesq's" speakers guess what my next project is? along this line does anyone know what the 3rd wire in the power connector is for? there is the switched power, ground and? I was hoping it was constant power but no luck, and does the dash speaker grills come out from the top to replace those tired OEM speakers? Thanks again. -JSP2242
