Bonehead Mistake = Possible Engine Damage?
My stock, lower mileage '66 327/350 roadster was in winter storage up on my lift, with zero signs of oil leakage (epoxy floor below with no drips). I just got this car prior to winter and had not had time to dig into it. It is very stock, and in excellent shape throughout.
Now the stupid part: I fired the car up this weekend, oil pressure came right up and after checking knockoffs, tire pressure, radiator fluid, etc. I took it for a spin. On the way home after a good 100 miles or so, I rounded a corner at low speed and noticed the oil pressure gauge bounce to zero, back to 40 and then back down to 0. I immediately pulled over, shut down, and restarted. Zero oil pressure. Checked dipstick and remembered that this car needed a change in the Fall, but that since winter hit so fast I had put it in storage and not done the change!!! Oil barely registered on bottom of dipstick. I was close to an auto parts store, re-filled the motor (only a few blocks from home) and pulled into the garage.
The motor is not making any unusual noises, pressure comes right up to 40 on starting and stays there, and there are no unusual noises even up to 4K on the tach.
Can anyone weigh-in on on whether there is there a strong likelihood that I have spun a bearing, etc.? I cannot flipping believe that I did this. - Completely bone-headed move on my part.
Change the oil and filter and keep a close eye on the oil level and the pressure guage . Don't forget to check the rest of the fluid levels .
Bill
.down
.Just kidding. You probly saved the engine by watching the oil pressure like a hawk. Good job.
Did I scare you?
My advice would to be VERY careful at this point. You probably got SUPER lucky, but treat her gently for a while and change the oil frequently keeping an eye on what comes out.
I dont think you need to worry to much about enginedamaged from the occasion you ar describing.
After i broke my engine last summer due to oilpressure drop i searched for information about this to prevent it from happend to my new engine.
And as I understand it, a couple of seconds of oilpressuredrop on low rpms and with a low oiltemp doesnt normally brake the lubricating film keeping the rods from hitting/destroing the bearings.
My engine (stock 300hp bigblock) broke after more then 2 days of driving on the track.
I did continously loosing oilpressure during breakeing and in left hand corners.
I didnt bother since this was the last event for the season and the building of my new engine already was in progress so i just kept going.
The oiltemp went high (noticed that pressure dropped) and i didnt eased of on the throttle in any of the corners.
In one of the long left hand corners i lost oilpressure when braking, cornering and under acceleration..
This resulting in that the oilpump blowing air instead of oil and as i understand it, blowing away the lubricating oilfilm from the bearings.
However, my bahaviour is a very good template of "how to brake a engine" and if you like to keep your engine alive dont do what i did.
Always check your oil level, oilpressure and if you drive hard for longer periods you will get high oiltemperatures so make sure you have a good oil, oilcontroll and an oilcooler to keep the oiltemp under controll.
Here is a little film of my stock -72 on roadtires from the event (never mind all the others driving faster than mee).
And you guys who havent yet tryed your C3 on a track.. -Just do it!!
Its soo much fun!!
http://www.youtube.com/watch?v=YlJoN...eature=related
P.
Let it cool overnight after filling the overflow with antifreeze...all of that sucked back into the radiator. Test drove it again after I'd redone the installation of the thermostat right, wrench in the car, drove around the block, darned temp just kept climbing again...drove in garage and four hours later cooled enough to open the radiator cap...lots of coils and air in there...it had sprayed out much more fluid than i thought so I put three more quarts in, closed it up, test drove it, 160 degrees like a clock. I felt terrible driving it the mile plus home originally that hot but it does not seem to have hurt it.
Second mistake was not carrying a 9/16" socket wrench. Third mistake was forgetting to check the radiator instead of relying on the overflow to fill.
won't make these dumb-*** mistakes again.
lance
Go around a corner, pressure goes to zero, time to add a qt.. I am like the others, it it probably fine. mike...
