Brake question
Old Jun 15, 2011 | 10:09 AM
72 bucket of parts's Avatar
72 bucket of parts
Default Brake question
Does anyone have a picture of the rod that goes between the brake booster and the master cylinder? Mine was not in any of my boxes and I don't know what the booster end looks like. I also don't know how long it should be. Any idea where I could get one? I have done some looking online but don't see anything.
Old Jun 15, 2011 | 09:00 PM
shrekviper's Avatar
shrekviper
Damn, just installed mine. It's about 2.5-3 inches long, flat on the booster side and rounded at the MC side. Haven't found a picture or where you can get just the rod...
Good Luck
Old Jun 15, 2011 | 09:05 PM
rugerm44's Avatar
rugerm44
Zip Corvette.
Old Jun 16, 2011 | 12:35 PM
72 bucket of parts
here are some pictures of one I got out of a Nova in a savage yard. It is longer than 3 inches, but the end is flat. When installed it looks like it is even too short.
you can see it doesn't stick out from the booster much.
Kelley
Old Jun 17, 2011 | 12:11 AM
shrekviper's Avatar
shrekviper
I figured it's only two bolts, so...
Here's what's hiding in mine. This is a replacement booster/m-c from autozone (matches what I had there before)
The rod is 2.5" long and 3/8" in diameter.
Installed
Old Jun 17, 2011 | 02:33 AM
noonie's Avatar
noonie
Kelley
The booster end of the rod is correct.
From the looks of it you have the long style booster with the short style rod installed and it should work with a short style master (77 and later).
Old Jun 17, 2011 | 08:02 AM
72 bucket of parts
Thanks for the pictures shrekviper. That helps. Noonie by later you mean newer, correct? Mine is a 72. The well in the mc is close to 2 inches I think. I will messure it tonight when I get home. If I understand what you are saying, then my rod is too short. The booster end seamed to fit good. Just a lot of peddle travel.
Kelley
Old Jun 17, 2011 | 10:04 AM
noonie's Avatar
noonie
Kelley
Yes, your rod is too short to use in the 72 mc. You have the proper 72 booster.
You could use a later 77+ mc with a shallow hole in the mc and it will work. The only difference in the masters is the depth of the hole in the piston.
Old Jun 17, 2011 | 10:08 AM
72 bucket of parts
Thanks for the information, I think I know what I didn't know now. Just need to figure out if I want to buy another mc or find a rod.
Thanks again.
Kelley
Old Jun 17, 2011 | 11:19 AM
noonie's Avatar
noonie
See if your short rod measures 4.926".
Old Jun 17, 2011 | 11:20 AM
72 bucket of parts
I will measure it tonight. Do you know what the long one measures?
Old Jun 17, 2011 | 01:10 PM
72 bucket of parts
Measured it over lunch. Just under 5 inches.
Kelley
Old Jun 26, 2011 | 05:34 PM
72 bucket of parts
thanks guys. got a 79 master cyclinder and all is good. Have power, brakes and stearing. It is mobile.
Kelley
Old Jun 26, 2011 | 08:29 PM
rugerm44's Avatar
rugerm44
just how deep is the shallow mastercylinder compared to the older deep one.
Old Jun 27, 2011 | 12:27 PM
72 bucket of parts
the '79 just has a rounded indention in the end where the rod goes. The '72 has a hole that is about and inch and a half deep.
Kelley
Old Jun 27, 2011 | 12:30 PM
rugerm44's Avatar
rugerm44
Thanks,just curious.
Old Jun 27, 2011 | 12:32 PM
rugerm44's Avatar
rugerm44
Is the piston interchangeable in-between the two.
To Brake question
