82 corvette radiator maintanace
Old Jun 15, 2011 | 10:32 PM
rzkas's Avatar
rzkas
Default 82 corvette radiator
Hello,
I am planing to working on my engine cooling system. i am going to change my upper and lower radiator hoses coz they are bad and also power rinse/flush my radiator and add in new coolant.
i need the best coolant for this car. currently the car has a 1978 400 small block engine with a carb. i need the name of the coolant and what type. mix or concentrated.
when i empty the radiator what type of coolant should i add in? and how should i refill my radiator to remove all air.
currently my car over heat after driving it for about 15 to 20 mins. i noticed that my lower hose is bent in way that the water flow/passage is so small/squeeed.
thanks
Old Jun 16, 2011 | 11:16 AM
terry82's Avatar
terry82
you should be able to use any off the shelf coolant if you are not having a problem .the hose bending like you said is a problem.get a new hose and see if it has a spring inside.that should fix your problem.
Old Jun 16, 2011 | 06:02 PM
rzkas's Avatar
rzkas
i went into autozone and bought a lower hose but they gave me the oem hose. is there any problem with stock/oem hose type? where can i buy a spring reinforce lower hose for a 82 corvette
Old Jun 16, 2011 | 06:25 PM
terry82's Avatar
terry82
look inside the one that they tryed to sell you .i would try napa
Old Jun 16, 2011 | 06:32 PM
rzkas's Avatar
rzkas
it doesn't have any spring in the inside and i have tried looking for a 82 corvette hose with spring, and i was not successful to find one. pls send me a link where i can buy this item. thank
Old Jun 17, 2011 | 09:40 AM
1nicecorvette's Avatar
1nicecorvette
IS THE RADIATOR HOSE YOU HAVE ON THERE CORRECT to begin with? sounds like its too long and bending up on you. if the hose is collapsed just sitting cold there then its def time to replace and an OEM one from napa would work fine.
Old Jun 17, 2011 | 11:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rzkas
...i noticed that my lower hose is bent in way that the water flow/passage is so small/squeeed...
Wrong hose. The correct lower hose will not be kinked or squeezed.
Old Jun 18, 2011 | 11:21 PM
rzkas's Avatar
rzkas
i know. i have two brand new hose. one for upper and one for lower. but my main concern is how to fill the radiator tank without any air trap inside and also what type of coolant or brand name coolant i should use. green color or pink color?
thanks
Old Jun 19, 2011 | 10:13 AM
Easy Mike's Avatar
Easy Mike
...green color or pink color?...
What's in the car now? You are not likely to completely drain the entire system, so some old residual will remain. You should not mix green and pink.
Old Jun 21, 2011 | 02:01 AM
rzkas's Avatar
rzkas
it green now
Old Jun 21, 2011 | 10:15 AM
terry82's Avatar
terry82
green is what should be in there .that is the old stuff before the pink .fill up the radiator.put the cap on ,then add some to the overflow tank .start it up and see were the level in the over flow goes .you should be fine .
Old Jun 23, 2011 | 12:24 AM
rzkas's Avatar
rzkas
where should the water be in the over flow at this time; when the engine is running. below or above which line? thanks
Old Jun 23, 2011 | 01:39 AM
noonie's Avatar
noonie
I usually top off the radiator hot and fill the overflow tank full. After a couple of heat/cool cycles the overflow should end up approx half full when hot.
Old Jun 27, 2011 | 10:50 AM
rzkas's Avatar
rzkas
ok. when you say hot, you mean just when you start the car and the car running correct. Coz i am afraid of hot radiators and it coolant. i don't want to get burn.
Old Jun 27, 2011 | 11:51 AM
Easy Mike's Avatar
Easy Mike
Do you have an owner's manual? The manual usually has a blurb about filling the system and proper coolant level.
Old Jun 30, 2011 | 05:46 PM
rzkas's Avatar
rzkas
I don't have an owner manual
Old Jun 30, 2011 | 08:07 PM
killain's Avatar
killain
Oldtimer
Default Correct colant amount ?
Just like the folks said above, fill the rebuilt or re-cored radiator and start the car, Leave the cap off. But I should point out that the lower hose MUST HAVE a spring in it. If it does not then when your out driving, and try to speed up, the vacuum or suction from the water pump is going to collapse the lower hose, temps. go up until you pull over and let it idle, at idle the suction is so low the engine cools off and you may think it's OK but once you get going again it'll happen all over again.
On my 79, I went to a junk yard and took the springs out of five cars and once home I cleaned them up and I put one in the upper hose as well as the lower, The lower already comes with a spring in it. (But go to NAPA cause the lower hose on any car needs to have something to keep it from collapsing under normal driving operation. I put one in the upper hose because it too, will collapse once the engine cools off overnight and I didn't like the look of the long 'S' bend hose collapsed.
But fill the radiator with a gallon of green and then a little water and back to green and once the engine is above 195 degrees, your going to be able to see the thermostat open and the mixture will be flowing across the radiator and you'll be able to see it flowing, Ok put the cap on it and turn it till the two arrows are pointing at the overflow hose. run the car around and once you get back, make sure the radiator overflow tank has enough coolant that it is at or slightly above the full 'Hot' mark.
Leave the car alone and get some sleep. The next morning come out and open the hood and check the radiator overflow tank. you'll see the level of coolant in now below the hot and sometime the 'Cold' mark, fill it with a little green antifreeze and a little water to bring it up to the 'Cold' mark on the tank. Once the engine gets hot and everything is working, there's some air in the system and allowing to sit over night, the engine cools off and creates a vacuum and sucks some of the anti-freeze back into the engine/radiator. I hope I've been of some help, I've done this job at least twenty times and I know it's frustrating the first time around.Good luck !
Old Jul 5, 2011 | 01:15 AM
rzkas's Avatar
rzkas
ok thanks for the info about the spring. those 82 corvette radiator oem hose for upper and lower comes with spring inside?
To 82 corvette radiator maintanace
