Replacing review mirror glass
Old Jun 16, 2011 | 03:21 PM
sabre1981's Avatar
sabre1981
Default Replacing review mirror glass
Has any one replaced the glass in the review mirror for an '81? Mine is really pitted; I bought a replacement from a local store, but it vibrates pretty bad. Since the original doesn't, I thought I could just replace the glass, but I'm having trouble popping it out. I've tried heating it up with a hairdryer and that seemed to help, but still couldn't get it to pop out and I cracked the plastic a little in the corners. I'm wondering if its actually glued to something and not just sitting in there. Any advice? Thanks.
Old Jun 16, 2011 | 04:50 PM
THefley's Avatar
THefley
My 81 in the same shape and I was wondering if I clould replace just the glass
Old Jun 16, 2011 | 05:48 PM
flaco1801's Avatar
flaco1801
my 74 was glued on....i was able to get the trim to the point where i was able to pry the glass off....i think i got the trim off completly, dont remember...once the trim is off the rest is easy.....i just laid the replacement glass in without glue and got the trim back on...wish i would have done it years ago....
Old Jun 17, 2011 | 01:18 PM
BTGRN75's Avatar
BTGRN75
St. Jude Donor '11
Bought glass for my 75 (has the map light). The original is REALLY glued in. I broke the glass-removed-then the new glass goes in easy.
I originally tried the hair dryer and ended op stretching the plastic trim. Should have broken the glass first! Good luck
Old Jun 17, 2011 | 04:48 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Soaked my '71's in gas overnight, glass fell right out. Probably not good for paint, tho!
Old Jun 17, 2011 | 08:56 PM
sabre1981's Avatar
sabre1981
Mine is all plastic, can't imagine it'd survive a gasoline soaking.
Old Jun 17, 2011 | 08:57 PM
sabre1981's Avatar
sabre1981
If they can cut a new one without needing the original, then I suppose it's not such a bad idea.
Old Jun 17, 2011 | 11:52 PM
THefley's Avatar
THefley
i was in safe light glass today about a chip in windshield and asked about the mirror and she looked in her book and had found a couple of options she can still order for this age of car
Old Jun 18, 2011 | 02:01 PM
Tom73's Avatar
Tom73
What type of glue is used to glue the mirror glass to it's rubber surround?
Tom...
To Replacing review mirror glass
