Engine Matching Numbers?
Old Jun 18, 2011 | 10:23 AM
allansmith79's Avatar
allansmith79
Cruising
Default Engine Matching Numbers?
If the head cast date is two days prior to the block cast date, is the engine considered a matching number engine? I have heard that the block cast date should be the same or prior to the head cast date.
68 427/390 HP Engine
Block dated A-10-8
Both Heads Dated A-8-8
Old Jun 18, 2011 | 11:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by allansmith79
...If the head cast date is two days prior to the block cast date, is the engine considered a matching number engine?...
Not necessarily.
... I have heard that the block cast date should be the same or prior to the head cast date...
Where'd you hear that?
...Block dated A-10-8...Both Heads Dated A-8-8...
Those are okay, but you could have heads cast after the block and could still have numbers matching. You could have heads cast on different days, even different months, and still be okay on the numbers.
The important thing is that all of the casting dates must precede the engine assembly date stamped on the pad on the block at the front of the right head. The VIN derivitive will also be stamped there.
If your heads were cast on the 8th and your block was cast on the 10th, your engine assembly date must be after the 10th. Occasionally you will see assembly dates the same as a block casting date, but usually not.
If the assembly date stamped on the block is before the 10th, you have trouble since the engine could not have been assembled before the block was cast.
Old Jun 18, 2011 | 03:05 PM
vettebuyer6369's Avatar
vettebuyer6369
Block dated A-10-8
Head numbers do not match.
They can be the correct head number for that car's application, and the date can be within a reasonable and acceptable time frame. However, there is no number on the head that MATCHES anything.
The only numbers that matter that actually match are the VIN on the body and the engine pad derivative and the transmission case.
Loosely, the trim tag color codes can match the body and interior colors.
Old Jun 19, 2011 | 04:34 PM
Mike Ward's Avatar
Mike Ward
Ooooh looky, another new definition of 'matching numbers' to add to my collection
[/sarcasm]
Old Jun 19, 2011 | 07:51 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
[/sarcasm]
New? Really? If people insist on using the ridiculous term "matching numbers" then VB's explanantion is the only one that makes sense. It was probably the original intention of the term but for whatever reason, people have chosen to complicate an otherwise simple issue. We would all be better off if it would just disappear from the entire collector car vocabulary, but that just ain't gonna happen. The genie is out of the bottle. I personally don't use it...anymore.
Old Jun 19, 2011 | 08:03 PM
scottyp99's Avatar
scottyp99
"numbers matching" means the number on the stamp pad matches the VIN. That's it. Nothing else. OK, fine, the tranny, too, but people don't seem to get as wrapped around the axle with the tranny as with the engine. Personally, I don't see what the big deal is......It has the original engine.....big deal. Does it have the original brake pads? Tires? Spark plugs? etc? probably not. Who cares, a nice car is a nice car.
Scott
Old Jun 19, 2011 | 08:35 PM
Mike Ward's Avatar
Mike Ward
Those are definitions #3 and 6 on the list of at least 15 I think, each of them the being THE REAL definition and all others are wrong
Old Jun 19, 2011 | 08:55 PM
BBCorv70's Avatar
BBCorv70
What if the VIN on the windshield pillar matches the number on the frame and transmission? 3 out of 4 make it matching numbers?
There's an article written several years ago which touched on the origins on matching numbers. It can be found in the C2 section. From memory, the original thought was if a Corvette had an engine block with the original VIN derivative it was probably low mileage and/or pampered since people would routinely pull them out and put another in its place if the original had any significant issues. A general indication the vehicle was worthy of restoration. Since this term now equates to a significant increase in value people go to great lengths to save the original block which would otherwise have been thrown away. Others made an industry of faking original blocks...
The article went into great detail regarding what matching numbers meant at that time. Much more than indication the block was original. Pretty much any part which had a part number and date code became part of the criteria for matching numbers.
Old Jun 19, 2011 | 10:26 PM
scottyp99's Avatar
scottyp99
Definition #16: My 1980 vette has 4 wheels and 4 tires. Yes!! 4 and 4, numbers match!!!!
Scott
Old Jun 20, 2011 | 11:25 AM
Easy Mike's Avatar
Easy Mike
Definition #16: My 1980 vette has 4 wheels and 4 tires. Yes!! 4 and 4, numbers match!!!!...
Not quite. Are the four tires mounted on the four wheels? Are the four wheels mounted on the car?
Old Jun 20, 2011 | 11:36 AM
Mike Ward's Avatar
Mike Ward
My Corvette has five wheels and five tires. Mine matches more than yours- nyah nyah.
To Engine Matching Numbers?
