Heater Vacuum Lines
Old Jun 21, 2011 | 11:57 AM
briaineo's Avatar
briaineo
Default Heater Vacuum Lines
Hi
I pulled my heater core recently has been block off since i bought the car ( the car also has AC ) and was hoping to change all of the vacuum lines alot were melted.
Not planning to use the AC in the near future or possibly ever!
Should I get the non a/c vacuum kit or the one that includes a/c?
Old Jun 21, 2011 | 12:39 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I would suggest getting the A/C kit. I don't know how many hoses are different in the two kits butthey are for the various under s=dash controls. Even if you don't use the A/C, the controls will have to be in place for the hea and vents to work.
Old Jun 21, 2011 | 01:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by CA-Legal-Vette
...I would suggest getting the A/C kit...
Non-AC controls are different and will not directly match up with the AC vac line connection.
Second option is to score a stock non-AC control unit and use it.
Old Jun 21, 2011 | 02:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have some pics that will help you.. even if you do purchase a hose kit. I would go with the AC kit due to the heater control switches being different. If you don't use the AC, you can just bock off what you don't need or use.
Old Jan 17, 2012 | 10:26 AM
TWINRAY's Avatar
TWINRAY
Thanks for the above photo
To Heater Vacuum Lines
