68 Horn Button?
Thanks!
Pretty sure I could put a 68-69 cap and probably more on my 65 if I wanted to. The steering wheels themselves could easily interchange from 63 up to about 75 with the right hub.
The 63 column is about the same length as a 68 column, but I doubt highly that someone converted a 63 to use in a 68, it wouldn't be worth the trouble. They are completely different columns, and mount differently too.
There were an assortment of different horn contact/button retainers, used between 63 and 82. Other than the contact/retainer for the 76-79 "Vega" wheel, the diameter of the area where the cap attaches, is the same for all of them. As such, a 63-64 cap, will attach directly to a 68 retainer.
The 68 horn button isn't repro-ed. The one that most vendors list for the 68 (the one with the grained outer ring), is actually only correct for 69-75 non tilt/tele columns. The 68 button is actually closer in a appearance to the 67 button, but was black, not chromed. Either the 67 or 69-75 (non tilt/tele) will work on a 68, but neither is identical to the original cap.
I found this 63-64 @ Corvette America and looks the closest, but not exact. I guess I may have a 63-64 column as well?
