T top height
Old Jul 1, 2011 | 08:34 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Default T top height
Anybody have some insight as how to adjust the t-top height?
Looks like the pass side back of the panel near the center line has raised up. Doesn't look right.
Suggestions?
Old Jul 1, 2011 | 08:40 PM
Mooser's Avatar
Mooser
There are shims under the two tangs on the t-tops that go into the center bar.
Add or remove shims to correct the heights
One thing to keep in mind is that they are not supposed to be flush, seems to me the AIM says they should be slightly higher than the rear arc, something like 1/16-or 1/8, quite a bit but that's what it said.
I can check the exact amount or do a search, seems to me I found it online also
Mooser
Old Jul 2, 2011 | 07:59 AM
Mod75's Avatar
Mod75
Thanks for the heads up about the height not being level, will check it out in AIM.
Never really noticed it until i kept hitting the corner with the razor blade holder while stripping. Makes sense to have the tops higher than the arc.
Old Jul 2, 2011 | 08:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Fiberglass tops, more or less, fit flush. Glass tops are a little high at the halo panel. The fit of both types is in the AIM.
Old Jul 2, 2011 | 08:02 PM
ButchN's Avatar
ButchN
Mine were not flush before my WS R/R.
I had to adjust & redajust & remove some shims after the WS install.
Also, when you loosen the bolts you can kind of tilt the T so make sure when you retighten, you have them aligned & square to each other.
I do have a question, what is the halo, the interior center piece where the dome light mounts?
To T top height
