My L88 Hood
thanks and again awesome job from what I can see.
Working from a pair of carpenter horses.
1. Placed the hood scoop on the hood.
2. Center it and make measurement from both sides making sure they are equal. Draw a center line on the hood and hood scoop and align the two.
3. Use spring clamps to hold the back corners.
4. I used a small sharpie to outline the scoop on the hood. Then remove the hood
5. Then took 1 ½ masking tape and ran it along the marked line. The tape covering the inside of the outline .
6. I then used a saber saw to cut the edge of the masking tape (smaller than the hood outline). NOTE do not cut the hood frame at the back leave about six inches of the back of the original hood.
7. I then cut the “stinger” out of the front of the hood.
8. Using a T- Bevel across the top of the nose I found the angle of the two sides of the hood. I then took the T- bevel and found that angle on the center part that I cut out. Using the stinger I cut out as a template I traced and cut out a patch piece matching the angle of the hood.
9. Next I ground a bevel on the edges of the stinger patch and the hood, taped it from under nether I then glassed the two together.
10. Sanded (ground) the top flush and placed the scoop back on the car.
11. Now after moving the masking tape used a guide when cutting the hood place the hood scoop back on the hood.
12. Making sure everything is lined up and starting from the front screw the hood scoop to the hood using sheet metal screws. Alternated side as you go.
13. If everything looks ok (last chance to correct any misalignments) unscrew and lift the hood scoop off. Now generously apply fiberglass resin to the hood where the hood will bond and in the same order as before screw the hood back down.
14. After the resin sets up remove the sheet metal screws turn the hood upside down. You will notice the left over material of the hood I used a dermal with a cut off wheel to remove most of this extra material and then sanded it flush with the hood scoop.
15. Next use about three inch wide strips of fiberglass matting and overlay three to four layers glassing the hood scoop to the hood. (including the patch piece)
16. Next turn the hood over and grind a bevel on both the hood scoop and the hood making a v shape groove where they join each other.
17. Shred fiber glass matting and glass the top of the hood and the scoop together. After the fiberglass has hardened sand flush.
18. Next I laid the hood on its side and added resin and shredded matting to the inside of the back of the scoop where you could not glass the underside (that part I told you not to cut off). Rotate and do the other side.
19. Returning the hood to the horses I started to feather the hood and scoop using “Extreme Rage” Although the hood was pretty straight I needed to add filler to the two sides in the front to get them flat.
20. Next I sprayed epoxy primer to both bottom and top. I finish the top with a high build 2K urethane blocking between coats.
Thanks for taking an interest.
