grease ?
Old Jul 6, 2011 | 04:36 PM
My70's Avatar
My70
Default grease ?
Wanted to grease tie rods etc on my '70 - what type of grease do you guys like ?
Old Jul 6, 2011 | 06:51 PM
killain's Avatar
killain
Oldtimer
Default Grease options
You can use a tube of any good maker of Chassis grease. If you want, you can even go with a synthetic grease. Not real sure of how useful a synthetic grease would be in a mildly used Corvette, But ( A lot of Construction companies use it,) but they use it in the huge backhoes or front end loaders, bulldozers ect. There are a lot of makes, I use a tube of Quaker State, it's black, some greases are a different colors.
Old Jul 6, 2011 | 07:37 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I like red.
Old Jul 7, 2011 | 10:27 AM
My70's Avatar
My70
Originally Posted by Faster Rat
I like red.
Not knowing what the previous owner used, are there any issues with grease compatibility?
Old Jul 7, 2011 | 10:43 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I use Mobil 1 grease on everything but wheel bearings and I have never had any issues. For the bearings I use Timken grease.
Old Jul 7, 2011 | 01:39 PM
scottyp99's Avatar
scottyp99
Everybody with any sense at all uses McGillicuddy's Miracle Grease. It is impregnated with graphite to increase it's lubricatosity. It is loaded with monosodium glutamate, which bonds with road salt, thereby neutralizing it. It contains a proprietary, patented, ancient chinese secret which goes by the trade name "Chemical X". "Chemical X" uses the trace amounts of argon in the atmosphere to create an inert layer between it and the oxygen in the atmosphere, to eliminate corrosion. It also makes an outstanding floor wax and laxative.
Scott
To grease ?
