Tach Board & Filter
Old Jul 8, 2011 | 06:02 PM
Moxy Vette's Avatar
Moxy Vette
Default Tach Board & Filter
Hey Guys...I replaced my burned out tach circuit board
and filter. Nice to have the tach working. At first the tach worked when
I started her up, then within a minute or two, it quit. I thought GREAT!!!
I fried my new board. I checked connections.....everything was OK.
Started the car... no tach movement. I then by-passed the filter, and the tach worked. I tried several other things, but it boiled down to the tach filter again. I took the filter right out, and the tach has worked ever since. What do you guys think? Deny.
Old Jul 9, 2011 | 04:12 AM
hunt4cleanair's Avatar
hunt4cleanair
What year Corvette and what was the source of the tach board? I would be curious if some vendor has incorporated the tach filter function into the board, thus eliminating the need for the mounted one, tho I would think the signal would still flow thru. If you got it from Wilcox, you could ask his advice.
Of course, you could have a bad, new tach filter. Try another filter or your old one and see what happens.
Old Jul 9, 2011 | 11:49 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
My first thought... is there something spiking the tach wire. The reason I say this is:
1) The first tach filter was not good.
2) The first tach board was cooked.
3) another filter bad.
I'm not saying that is the case... but it surely would be something to check out.
Original boards and filters go bad all the time, so it may just be a case of a defective filter too... but well worth keeping an eye on.
Willcox
Old Jul 9, 2011 | 07:20 PM
Moxy Vette's Avatar
Moxy Vette
Default Faulty Filter
Hi , The tach has been working great without a filter for days. I am running a new Mallory HEI Distributer as well. Must be a bad filter. The tach is reading smooth and steady. I will go filterless for now. Thanks for the input, Deny.
To Tach Board & Filter
