seat swap
Old Jul 10, 2011 | 03:35 PM
81shark2008's Avatar
81shark2008
Default seat swap
about to purchase a set of clam shell seats from an 81 for my 81 my car is not power seats but this set is on drivers side. will these still fit the same or be able to be made to fit or isit not going to happen and a waste of money? thanks
Old Jul 10, 2011 | 07:22 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I purchased a set of seats out of an 82 CE for my 76. I successfully installed the seats using my original tracks - still in the car today, 9 years later.
Just remove the tracks and use yours and they should fit fine.
John
Old Jul 10, 2011 | 09:19 PM
81shark2008
thats what i thought but wanted to be sure they were just higher tracks and not the actual seat bottoms themselves
John
Old Jul 10, 2011 | 10:41 PM
eagle275's Avatar
eagle275
I have a '71 vert, and may use some seats out of an 80. Will my tracks fit the same on these, like my origional seats?
Old Jul 12, 2011 | 01:00 PM
Go Vette Go
I don't know about the 71 tracks fitting, I do know I had issues with the stock tracks from my 69 fitting the 79 - 82 style seats.
Old Jul 12, 2011 | 03:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check your driver's side floor pan for an indentation to clear the driver's power seat motor. I believe all 81 pans had the necessary indent, but check.
If the indentation is there, you can bolt in the power driver's seat.
AIM shows the entire instalation, including the wiring for the seat.
Old Jul 12, 2011 | 03:20 PM
Easy Mike's Avatar
Easy Mike
Seat tracks will not help if you cannot clear the power seat motor. Check your driver's side floor pan for the indentation needed to clear the motor. I believe all 81s had the indent, but check.
If the indentation is there, the power driver's seat will bolt in. You must use the power seat track assembly.
AIM shows the entire installation, including the wiring for the power seat.
Old Jul 21, 2011 | 09:38 PM
eagle275's Avatar
eagle275
Mike, thanks for the info. My seats are non-power. Could be from a 79 or 80.
To seat swap
