reducing interior heat
Old Jul 12, 2011 | 10:38 AM
big_beau408's Avatar
big_beau408
Default reducing interior heat
What is the best way to handle interior heat on the drivers side. When driving my '74 its almost unbearable. The passenger side is fine. When
I pulled the carpet back by the steering column I could actually see through to the engine. Is this where all the heat is coming from? Thanks for any suggestion! Bruce
Old Jul 12, 2011 | 11:36 AM
ED79's Avatar
ED79
I would have to say yes, any openings to the inside from the fire wall will give unwanted heat in the summer cold in winter. To help with keeping heat out, I put a heat barrier between the carpet and floor, it made alot of difference. Hope this helps, Ed
Old Jul 12, 2011 | 12:12 PM
Sharkey1807's Avatar
Sharkey1807
Seems you're missing the interior insulation.
Cheaper then now it never will be.
Vettenuts has a introduction pirce for a hole set for only 110$.
Complete interior and also doors.
Just bough a set yesterday.
But other manufacturers/resellers they go for 179$, but for that the doors are not included !
C3 Pre-cut Insulation kit
This will solve your heat problem for good.
Robert
Old Jul 12, 2011 | 02:02 PM
jcloving's Avatar
jcloving
I put down Hushmat and Reflectix on the floorpan, tunnel, waterfall, firewall and some of the cowl. I patched all the holes and replaced the missing grommets. It smells better in the cabin and the heat is gone.
Old Jul 12, 2011 | 02:22 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Reflectix at home depot for 25.00
Old Jul 12, 2011 | 03:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by big_beau408
...When I pulled the carpet back by the steering column I could actually see through to the engine...
That's a No-No. You should not be able to see from the interior into the engine compartment.
Old Jul 12, 2011 | 10:24 PM
Kahle76's Avatar
Kahle76
Check your air dam. When I added mine, it made a noticable difference.
Old Jul 24, 2011 | 05:39 PM
JohnRR's Avatar
JohnRR
My '73 was hot as hell too. So I tore everything out and installed Dynamat for sound reduction on the floor, then 1/4"-1/2" Dynaliner on top of that for heat reduction.
I also installed some "Zero Clearance" insulation under the floor to block the exhaust pipe heat. It is self adhesive, hight temp insulation with a heavy aluminum covering. It can be bought from the mail order speed shops like Summit or Jegs.
If you have a clutch, there is a rubber seal around the pushrod on the engine side that is easy to replace.
One other thing, the steering wheel assembly is supposed to have three gaskets where it mounts to the firewall. A big one on the inside and two little donuts on the outside.
John
Old Jul 24, 2011 | 11:36 PM
dboz's Avatar
dboz
They don't call it a firewall for nothing. You don't want to risk having that opening, god forbid, the worst should happen and you get an engine fire!!!!!!
Old Jul 25, 2011 | 07:34 PM
texaswilkins's Avatar
texaswilkins
Post a picture of that spot and someone here can tell you what you are missing. If you are in the DFW area come on over I have a couple here that you can look at too.
Bill
Old Jul 25, 2011 | 08:44 PM
wgarneau's Avatar
wgarneau
Isn't there supposed to be, like, METAL between the driver and the engine???
Old Jul 25, 2011 | 09:28 PM
oldboat's Avatar
oldboat
JohnRR
how does the zero clearance stuff hold up when it rains, snows, and gets sloppy outside?
Old Jul 25, 2011 | 10:27 PM
aussiejohn's Avatar
aussiejohn
G'day,
Not in a pre '76. They were all fibreglass.
Regards from Down Under.
aussiejohn
Old Jul 26, 2011 | 12:14 AM
JohnRR's Avatar
JohnRR
I have had a lot of this on my '09 Z06 in plenty of rainy days. It looks the same as when I installed it 3 years ago. Although, I have to admit I don't know how snow affects it
John
Old Jul 27, 2011 | 09:41 PM
oldboat's Avatar
oldboat
thank you
To reducing interior heat
