Shoulder belt mounts
Old Jul 13, 2011 | 09:00 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Default Shoulder belt mounts
I'm getting ready to put C5 seats in my '70 coupe and was wondering how everyone has routed the shoulder belts since there's no seat bracket to run the belt through. Any ideas?
Old Jul 13, 2011 | 11:09 PM
Phlash's Avatar
Phlash
I wanted shoulder belts in my 72 convertable. Some have used rear belts out of camaros and firebirds. I didn't like them, since the factory belt female receiver also had to be changed. Instead, I took my receiver to a local salvage yard and found that the rear belts from an Oldsmobile Aurora has a retractor that will mount on your rear fender well (if yours is equiped), and allows you to use your factory female receiver buckle next to the console. I am 6' 1" and the belt is just long enough to fit me comfortably. If you are much taller, you might have to extend the belt anchor with a piece of metal strap.
Old Jul 13, 2011 | 11:14 PM
Raphiki's Avatar
Raphiki
Thanks for your help. What I'm trying to do is come up with some method of mounting a seat belt guide or bracket somewhere over my shoulder to do the job that the hole through the seat used to perform. I don't know if there is any way to do this.
Old Jul 14, 2011 | 08:55 AM
RobRace10's Avatar
RobRace10
I converted my Standard C5 seats to Sports Seats then the belts run through the back, I also have a Shark Bar to mount the shoulder belts to.
Old Jul 15, 2011 | 12:19 PM
Raphiki's Avatar
Raphiki
Anyone else still using shoulder belts with after market seats?
Old Jul 15, 2011 | 10:13 PM
DC3's Avatar
DC3
I have '79 seats in my '73. I'm using a set of Camaro seat belt guides:
They also make a version that has a slot in them for the belt to slide into.
I cut the slot into the ones I bought. The '79 seats have a hard shell that these guides could be bolted to. Don't know if you could use them for the C5 seats or not.
DC
Old Jul 16, 2011 | 02:37 AM
RickyBerg's Avatar
RickyBerg
There is a hole in the back of the seats, its just hidden under the seatcover.
What i did was to losen the backplate of the seat and the trimplate (front) and losen up the seatcover so the belts passage is visible.
Then just cut a hole in the right spot in the seatcover, cut a hole in the trimplate with a Dremel or small high speed air-grinder.
Apply the belt guide and the trim beezel in the holes prepaired by the factory.
Route the seatbelt through the seatback.
This is easily done thanks to that the belts fastener is made to be removed for this operation.
Sorry if the spelling may be a bit out (language)..
//Ricky.
Old Jul 16, 2011 | 02:40 AM
RickyBerg's Avatar
RickyBerg
Location of the hole for the belt in the seatback.
Old Jul 16, 2011 | 02:42 AM
RickyBerg's Avatar
RickyBerg
These are the items needed for the seatback.
My car is a 72 so check for posible differenses to your 70.
This is the kit i bought at Ecklers
Funny thing is that not everything shown on the picture was included..
Old Jul 16, 2011 | 02:44 AM
RickyBerg's Avatar
RickyBerg
Front trim plate after cutting the hole out.
Painted with flat black and then the edges was polished shiny again.
Old Jul 16, 2011 | 09:46 AM
Cleon's Avatar
Cleon
Default 1979 Corvette
I replaced the OEM seats with Corbean seats and Corbean shoulder belts. I used a Harness Bar to attach shoulder belts, at shoulder height, did not want to attach to floor. Floor mounted shoulder belts will not keep you from going forward in a crash. The Harness Bar also gives the car some body support, and stability. All works well. Have not need them in a crash. The seats are more comfortable than the OEM.
Old Jul 16, 2011 | 01:34 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have C5 seats in my '72, and I have been trying to come up with some sort of idea for shoulder belts as well. The '72 stock shoulder belts won't be long enough to attach to some kind of holder mounted on the pillar.
Here are some pics I have collected during my research. I have no idea who owns these cars. The first one I think is a stock set up from a later year, not sure what year though. I don't know yet if the quarter panel trim would fit in an earlier car like mine:
The next two pics I do not think are stock set ups:
The last few pics are someone's custom creation:
Old Jul 16, 2011 | 06:49 PM
Raphiki's Avatar
Raphiki
That's what I'm looking for! Thanks everyone!
To Shoulder belt mounts
