? about GF432 fuel filter
Old Jul 14, 2011 | 10:24 AM
TWINRAY's Avatar
TWINRAY
Default ? about GF432 fuel filter
I bought my '69 in 1973 and even then it had the bubba cut fuel line with the generic Fram fuel filter held on by worm gear clips. Is this the mod everyone did back them when, I guess, either the GF432's were discontinued or were felt to be more expensive than the Frams.?
Old Jul 14, 2011 | 12:59 PM
PRNDL's Avatar
PRNDL
I have never seen that particular filter. The most common alteration I have seen is disconnecting the fuel return line and using an aftermarket pump to carb fuel line that takes some kind of inline fuel filter (with no return line outlet).
Old Jul 14, 2011 | 02:36 PM
knockbill's Avatar
knockbill
more or less,,, tahts the way my 68 was when i got it in 85...
Old Jul 14, 2011 | 03:06 PM
Jeff_Keryk's Avatar
Jeff_Keryk
My 68 had rubber everywhere when I got it. And I think it had been drag raced, because of the Mickey-Mouse cam... Now she's pretty much stock.
Old Jul 14, 2011 | 03:42 PM
...Roger...'s Avatar
...Roger...
I believe some were confused by the return because it lowered the fuel pressure at the carb,probably thought it was hurting performance.
And if I remember right Fram had 432.
Old Jul 14, 2011 | 03:48 PM
...Roger...
Wow
http://cgi.ebay.com/ebaymotors/Corve...item2a091df88b
Old Jul 14, 2011 | 03:58 PM
knockbill's Avatar
knockbill
Originally Posted by ...Roger...
roger,,,
tahts why you see so many cvars with the rubber hose replacements!!!!
Old Jul 14, 2011 | 04:03 PM
knockbill's Avatar
knockbill
i agree,,, i just changed teh fuel pump on my 68 last week,,, there are many "replacements" taht will fit, but the one it calls for (in the napa books, anyway), has quite a bit more pressure than the regular passenger car pumps.... i believe, if you plug teh return line, and use a generic 2 pipe filter, you are putting too much pressure on teh needle valve, probably a reason for running rich, and flooding?????
Old Jul 14, 2011 | 05:36 PM
427basketcase's Avatar
427basketcase
Corvette Centeral has the replacement for $42.00
here > http://www.parts123.com/parts123/yb....5Z5Z50000050G#
Old Jul 15, 2011 | 10:19 AM
TWINRAY's Avatar
TWINRAY
Thanks for all the replies. Yup, lots of bubba fixes. In any event, I've been running the generic Fram for close to 40 years but the in process resto has it being replaced with the #432 and "correct" pump to filter to carb hard lines.
Old Jul 15, 2011 | 10:20 AM
TWINRAY's Avatar
TWINRAY
Get your bid in quick
To ? about GF432 fuel filter
