Tilt / Tele Colum Differences
Old Jul 15, 2011 | 01:42 PM
kaiserbud's Avatar
kaiserbud
Default Tilt / Tele Column Differences
I want a tilt/tele column for my 69. I am open to non-1969 columns, but cannot recall the differences between the years. I will try to make a listing - can ya'll help? Please correct me if I am wrong - supporting pics are welcomed. Comments on pros/cons.
When did they go to the square housing?
Did wipers ever go to the column???
Old Jul 15, 2011 | 02:17 PM
69FASTFUN's Avatar
69FASTFUN
Here is a link to tilt columns
http://corvettecolumns.com/69-76rebuilds.htm
Old Jul 15, 2011 | 02:53 PM
kaiserbud's Avatar
kaiserbud
awesome....
Old Jul 15, 2011 | 03:00 PM
gbvette62's Avatar
gbvette62
The link given by 69fastfun has some excellent info.
Beyond what's listed there, the 78-82 column can be adapted for use in your 69. The 78-82 columns are a little shorter, and they have the dimmer switch as part of the turn signal lever.
77 columns are a one year only, and have the wiper controls as part of the turn lever, so they really aren't a good fit for any year other than 77.
Old Jul 16, 2011 | 09:03 AM
Jim Shea's Avatar
Jim Shea
Here is a paper on installing a 77 or a 78-82 T&T column into earlier C3Vettes.
http://jimshea.corvettefaq.com/wp-co...ev23FE2011.pdf
Jim
Old Jul 16, 2011 | 09:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No tilt for 68; tele only which is why they are always on the list by themselves.
Old Jul 16, 2011 | 11:59 AM
kaiserbud's Avatar
kaiserbud
Thanks Gents - greatly appreciate.
I will delete the summary above I started.
These papers/references are exactly what I needed.
Jim - do not know what we would do without you.
Old Jul 16, 2011 | 04:01 PM
AR71Stingray's Avatar
AR71Stingray
Cruising
I can't help you with your 1969, but I can speak favorably for Larry Smith (http://www.corvettecolumns.com/). He does a great job with the columns he sells (not cheap, though) and is very responsive.
I just recently installed one of his tilt/tele columns in my 1971 and it is a great improvement over the standard one. My old column felt loose and the rag joint needed replacing. The rebuilt one is tight and the tilt/tele is worth it.
Good luck with your 1969. I learned a lot removing mine and got into that "while I'm at it" mode and installed power brakes replacing the original manual system. Much easier with the column removed!
Old Jul 17, 2011 | 02:48 PM
kaiserbud's Avatar
kaiserbud
Yes - Larry and I spoke on Friday for quite a long time. He and I swapped Corvette stories regarding COrvette shops/people in the Houston Arlington areas. Enjoyed the hell out of it
Sounds like he has built a few columns....
To Tilt / Tele Colum Differences
