C3 Power window motor replacement?
Old Jul 16, 2011 | 11:55 PM
mellis40's Avatar
mellis40
3rd Gear
Default C3 Power window motor replacement?
Does anyone know if there is a way to lock the window regulator spring to remove and replace the power window motor without removing the door glass and window regulator? I know the instructions are to remove the regulator and rotate to line up a hole to place a bolt in to lock the spring prior to removing the motor. It appears if one knew just where to drill a hole to place a bolt to lock the spring without removing the regulator, it would be simple to replace the motor and save all the labor of removing the glass and having to go through all the adjustment procedure.
Old Jul 17, 2011 | 06:23 AM
demoke's Avatar
demoke
i replaced the pw motor on my 80 and did not have to remove the door glass or window regulator. see post http://forums.corvetteforum.com/c3-t...ment-pics.html
i did have trouble getting the teeth to line up exactly(3 bolt piece)- once i did this this, my new pw motor began working. good luck...
Old Jul 17, 2011 | 08:47 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Here is a picture of a driver's side door with the outer fiberglass skin removed. The hole to put the bolt through is the bigger one below the spring. In this picture, the window is not down quite far enough to get the bolt in, you can see part of the hole in the other part starting to show. You will have to feel for this hole since I don't think you will be removing the outer door skin!
Old Jul 17, 2011 | 08:56 AM
...Roger...'s Avatar
...Roger...
With the window 99% up ,put a couple plastic squeeze clamps on the glass,remove the motor,install new motor.
(If the teeth don't mesh,pull glass up the remaining 1% or lower it a tiny bit.)
Old Jul 17, 2011 | 09:44 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
Pulling the glass isn't that bad. Now, readjusting can sometimes be challenging. However, if you haven't pulled any of it apart, doing so lets you clean/update the nasty grease in the tracks.
Old Jul 17, 2011 | 11:23 PM
mellis40's Avatar
mellis40
3rd Gear
Thanks to all for the responses and the pics. This is on a '77 drivers side door. It has a new window glass, new regulator, and new motor with all channels cleaned and new grease. Had it replaced while in the paint & body shop. The new motor (made in China), from a Corvette vendor, quit working after being actuated ten or twelve times. I have been through the challenges of adjusting the window and that is what I'm trying to avoid. I checked out the wiring for continuity and voltage. Then unplugged the new motor and plugged the connector to my old motor and it worked, but ran slow. I'm thinking that cleaning the old grease off and replacing with fresh grease on the original motor may make it work better. The new motor is under warranty and I'm sending it back for a replacement, but don't have a warm feeling about trusting it. Where was the motor from Pep boys made?
Old Jul 17, 2011 | 11:27 PM
mellis40's Avatar
mellis40
3rd Gear
The motor quit working with the window all the way up. So as I understand it, plastic clamp the glass and remove the motor, that the up stops will prevent the regulator from moving.
To C3 Power window motor replacement?
