a/c overheats engine
Old Jul 17, 2011 | 06:10 PM
moeonrt66's Avatar
moeonrt66
1st Gear
Default a/c overheats engine
I have a 1978 vette 350 engine just put in a new air compressor but when I use air conditioner it over heats and the air only blows out of the bottom air vents, please help Thank you for any suggestions
Old Jul 18, 2011 | 02:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is the system fully charged?
Duct selection indicates you have a vacuum line loose.
Old Jul 18, 2011 | 08:21 PM
SIXFOOTER's Avatar
SIXFOOTER
agreed for the vent issue. For the overheating, check all the basics on the cooling system: Seals in place on the radiator, fan clutch is working, correct fan and shroud fit. If it overheats running down the road with the AC on, look at the air dam. Probably an airflow issue in there somewhere, or more than one.
To a/c overheats engine
