A/C Compressor Bolt Problems
Old Jul 22, 2011 | 05:59 PM
wgarneau's Avatar
wgarneau
Default A/C Compressor Bolt Problems
Hey Everyone!
My A/C Compressor is fine but the bolt that goes into the belt tension bracket won't tighten correctly. The threading in the hole in the compressor is toast. I noticed that the hole the bolt goes through goes all the way through the compressor though, an there is enough room for a nut if I get a longer bolt.
I'm sure you can see where I'm goin with this... Can I do that???
Old Jul 22, 2011 | 06:10 PM
Ganey's Avatar
Ganey
Yes w/ R4.
Old Jul 22, 2011 | 09:38 PM
wgarneau's Avatar
wgarneau
R4?
Old Jul 22, 2011 | 10:14 PM
wgarneau's Avatar
wgarneau
R4=A/C compressor model. I figured it out from the other A/C thread
Old Jul 23, 2011 | 06:50 AM
Paul L's Avatar
Paul L
What year?
Old Jul 23, 2011 | 08:13 AM
thegazman's Avatar
thegazman
Default thegazman
The belt tension bolt on my 79 with R4 refrigerant never did have threads. It has a long bolt that goes through the compressor with a nut on it.
Old Jul 23, 2011 | 08:39 AM
wgarneau's Avatar
wgarneau
It's a 78, and as soon as I get to the hardware store my AC compressor will be just like Gazman's
Old Jul 23, 2011 | 10:05 AM
08vycpe's Avatar
08vycpe
I bought a new compressor for my '79 last year. When installing I found the threads in the newly manufactured compressors are metric and back in '79 everything was SAE, including the bolt. I then bought a metric bolt to match the compressor but it would not fit through the slot in the bracket that is used for belt tensioning. I had to use my good old Dremel to widen the slot.
So to those who are buying new compressors be cautious about the fasteners before you strip out the threads.
Old Jul 23, 2011 | 11:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by thegazman
...my 79 with R4 refrigerant...
R4 is not refrigerant. R4 is the model of the compressor; the small radial type used on all Corvettes beginning during the 76 model year.
The older, longer cylindrical compressers are called A6.
Old Jul 23, 2011 | 04:45 PM
thegazman's Avatar
thegazman
Default thegazman
You are absolutely right and I know that. My mistake. Please forgive me.
Old Jul 24, 2011 | 11:57 AM
Easy Mike's Avatar
Easy Mike
...Please forgive me....
Absolutely.
Old Jul 24, 2011 | 03:09 PM
wgarneau's Avatar
wgarneau
I just finished. It works great...
To A/C Compressor Bolt Problems
