vacuum line question
Old Jul 25, 2011 | 03:11 AM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default vacuum line question
i just had my quadrajet rebuilt and noticed a vac hose off of the air breather is not hooked up. the hose comes from the intake side of the air cleaner and i think is some kind of flapper that closes when the car is cold . where should these be hooked up. each intake has one and they attach to a piece on the bottom of the air cleaner and then go open ended. do they need to be hooked up and if so where do they go? i see no open vac lines or ports on the carb.
also the car idles fine but when i turn on the a/c the idle goes up to ~2000 rpms/ i know that there is an electric solenoid that pops out to increase the idle to account for the compressor running but is there a way to adjust the idle down when the a/c is on?
Old Jul 25, 2011 | 04:22 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by hdff
i just had my quadrajet rebuilt and noticed a vac hose off of the air breather is not hooked up. the hose comes from the intake side of the air cleaner and i think is some kind of flapper that closes when the car is cold . where should these be hooked up. each intake has one and they attach to a piece (port?) on the bottom of the air cleaner and then go open ended. do they need to be hooked up and if so where do they go? i see no open vac lines or ports on the carb.
You don't state but I assume its the 78 L82 and if I understand your question and related description, sounds like that is the vacuum hose that comes out from two ports located under the air cleaner and routes to a port on the back side, bottom of the carb. There are color coded vacuum hose schematics that are great from reconnecting all those hoses. Seems like someone posted an electronic version some time ago here on the forum.
Both your shop manual and the emission sticker will list the specifications for adjusting the solenoid with A/C on. Your solenoid (M38) should have an adjusting nut but check the shop manual for proper adjustments.
Old Jul 28, 2011 | 11:03 AM
hdff's Avatar
hdff
thanks, yes it is for the 78 l82. i found a color coded vac hose chart on wilcox's web site but i don't see the hoses that go to the connection under the air cleaner
the solenoid looks like it can be adjustable i just wanted to ask here 1st , i don't have a shop manuel. thanks for your help...
Old Jul 29, 2011 | 06:03 AM
hunt4cleanair
Ifound a color coded vac hose chart on wilcox's web site but i don't see the hoses that go to the connection under the air cleaner.
I don't think technically it is an emission control hose but a "warm air" mechanism described as Thermostatic control. Thermac routes pre-heated air from the exhaust manifold into the air cleaner. The vacuum hose powers the flaps in the Thermac device and connects thru a temperature sensor, originally a green color that is located on the passenger side of the air cleaner base. On the L82, the driver's side connects to the probe underneath while the passenger side Thermac connects to a "T" which connects to both the other air cleaner port and the port on the base of the carb.
To vacuum line question
