Repro shift plate/bezel question
Who sells the most correct repro shift plate of our sponsors?
I bought one for my 82 from one of our sponsors, & it is not right.
The ashtray door would not close & I found it was about 3/16" too narrow & I was told by the sponsor to cut it, so I filed it ever so carefully.
Now, 2nd issue, when the door is closed it does not sit flush, but about 1/8" too high, as if the mounting tabs on the other side were molded to short.
So, who has had the best luck with a repro piece?
Oh, & it seems a bit too long as well.
And, not the sponsors fault, I know they buy elsewhere, but I do find it hard to believe when they say no one else has mentioned these things.
You also might want to find an original and restore it yourself. I have done some of the earlier C3's. It is a bit of work but you know it is going to fit.
Here is a pic of one I did.
BTW, great job Sarge on the console plate you restored.
68/70Vette's Law of Repro Parts:
1) If it fits, it's of poor quality
2) If it's of good quality, it won't fit
There are a few exceptions. A microscopic minority of repro parts manufacturers haven't got the message. Occasionally, you will find a repro part of good quality and will fit.
I have repro passenger and driver side dash panels, repro, to install. At first attempt they don't seem easy to install...easy? Don't know.
I installed repro rear quarter panels on my 68 Corvette convertible. At first attempt, they didn't look like they would fit at all. Actually, pushing and shoving and grinding some into the fiberglass supports got them mounted looking really great. Later, when Al Knoch and his merry men went to install a new convertible top, they removed these quarter panels and my first thought was these guys have just stepped in *hit because it's going to be hard to get the quarter panels back on. Wrong. they effortlessly installed the panels. Obviously when you have a lot of experience (read a career of experience), working with interior parts is a lot easier than what you or me will experience.
