79 headlights stopped working
Jul 31, 2011 | 02:20 AM
hey guys, the other night i noticed that my left headlight had stopped working, and today when i checked it out both have stopped. headlights pop up and down fine, it is the actual lamp. both turn signals are still working. all bulbs are still in tact. i have had a play around but cant get my head around it. all help appreciated
thanks, toby
Jul 31, 2011 | 10:27 AM
Did you try changing the the lamps?
Aug 1, 2011 | 02:56 AM
the lamps are fine, when they pop up the right one flashes on and then off for less than a second.
Aug 1, 2011 | 11:41 AM
Cruise-In II Veteran
Have you checked the fuse? Have you checked the wiring harness connectors on the rear of each lamp?
Aug 1, 2011 | 11:46 AM
Quote:
Originally Posted by
tobyj7
Interesting , very interesting.
Aug 1, 2011 | 11:51 AM
tobyj7
I would still check the lamps before doing anything else
Aug 2, 2011 | 02:35 AM
i have pulled the wiring harness off the lamps and they are fine, can someone clarify which is the headlight fuse
Aug 2, 2011 | 03:04 AM
i now have the high beams working, but not the normal lights so that means that lamps are fine, fuse is fine, maybe the switch?
Aug 2, 2011 | 06:59 AM
I would still swap out the lamp with a known good one....just to be absolutely sure. Pete
Aug 2, 2011 | 08:40 PM
Status check.....inquiring minds want to know! Hopefully it was an easy fix-Pete
