1981 corvette oil pan
Old Aug 1, 2011 | 09:13 PM
rvmunro's Avatar
rvmunro
2nd Gear
Default 1981 corvette oil pan
Has anyone replaced their oil pan in a 1981 corvette. Seems they changed the oil pan in 1980 . I can't seem to locate a aftermarket one locally. Everyone I talked too said the didn't have a listing even the local Chevy dealership. If any one has any ideas....
Old Aug 2, 2011 | 10:00 AM
81pilot's Avatar
81pilot
Yes, it is a small block Chevy Gen 1 passenger side dipstick pan. You can find that anywhere almost. Check the parts section a guy is parting out an 81, it might be worth looking into.
Old Aug 2, 2011 | 10:12 AM
qwank's Avatar
qwank
it also has a center rear drain plug
Old Aug 2, 2011 | 11:39 AM
81pilot's Avatar
81pilot
I personally don't care about originality, so I didn't metion that. The replacement I used has an offset drain plug, but you can get the correct ones.
Old Aug 2, 2011 | 02:01 PM
gbvette62's Avatar
gbvette62
The 81 Corvette uses the same oil pan as all 1980 to 1985 Corvettes. Bair's Corvette Parts (they're in PA, 814-683-4223) use to have a supply of original 80-85 GM pans. I don't know if they still have any, but it could be worth a call.
Corvette Central also offers a replacement 80-85 pan, chromed or painted, for around $100.
Old Aug 14, 2011 | 05:45 PM
rvmunro's Avatar
rvmunro
2nd Gear
thanks for the info...
To 1981 corvette oil pan
