I'm looking for advice on glassing in the holes without the use of a block off panel since the P.O. cut part of the rear clip so will need to do a fibreglass repair anyway.
Would I use a wire mesh to lay the the first layer of fibreglass matting down.
...the PO of my car cut away a little extra for custom exhaust tips...
Cut where? Inside edge toward the license plate, or outside edge toward the marker light?
If the cut is inside, purchase a replacement rear panel and you're home free. There is a raised lip on the panel at the exhaust cut out to mount the chrome bezel. You can try to replace/repair that, but the quickest and easiet fix would be to go to the replacement panel.
Stretch masking tape over the opening to act as a temporary backing for the new glass. Once it's set, the tape can be removed(although it may need to be sanded off).
