Blinkers issue
Old Aug 15, 2011 | 02:20 PM
trezdustrial's Avatar
trezdustrial
Default Blinkers issue
When I hit the brakes the blinker lights on the dash light up and the parking lights come on as well. Blinkers no longer work however....
I did replace a burnt out brake light which unfortunately did not fix the issue.
Recently had ignition lock cable replaced (couldnt remove key). This happened immediately after. Coincidence?
Any ideas? Thanks!
Old Aug 15, 2011 | 03:07 PM
...Roger...'s Avatar
...Roger...
Usually when the brake lights start lighting the parking light circuit its a lost ground somewhere. Crossing circuits can be from the 2 filaments in a bulb getting together.
Another thing that complicates the crossing of the 2 circuits is the side marker light bulbs,I always recommend removing the 2 front side marker bulbs until you get the problems solved.
