Right timing sprocket?
Old Aug 17, 2011 | 09:31 PM
ShootCraps's Avatar
ShootCraps
Default Right timing sprocket?
I ordered a new timing set for my '75 and here is what I got (item C-3023X from Autozone):
[IMG][/IMG]
It appears to be about an inch smaller in diameter than the original:
I'm thinking this will not work. Am I right?
Old Aug 17, 2011 | 09:56 PM
'75's Avatar
'75
It looks right, just doesn't have the nylon teeth like the original GM ones.
Old Aug 17, 2011 | 10:57 PM
DRIVESHAFT's Avatar
DRIVESHAFT
That part number is correct for your car. It looks like it should work.
Old Aug 17, 2011 | 11:09 PM
ShootCraps's Avatar
ShootCraps
Thanks!
Old Aug 18, 2011 | 07:53 AM
ShootCraps's Avatar
ShootCraps
So why won't the diameter of the sprocket change the timing?
Old Aug 18, 2011 | 08:29 AM
jackson's Avatar
jackson
crank-to-cam relationship always 2turns:1turn
what matters is how many teeth each gear in the SET has
18:36 ... or 22:44 ... makes no matter so long as cam has twice as many teeth as crank ... cam turns half-speed of crank ... many C-3023X installed pre-'86 sbc ... it's correct for sbc C3
Old Aug 18, 2011 | 10:26 AM
ShootCraps's Avatar
ShootCraps
Great explanation! Thanks.
To Right timing sprocket?
