Brake Light Question
Old Aug 23, 2011 | 11:49 PM
couperdecar's Avatar
couperdecar
Default Brake Light Question
Coming to work tonight with the '79 , I was rolling along about 25mph and coming to a stop light. There was a very very slight pull to the right as I touched the brakes. VERY Very slight. Anyway once I came to a complete stop the brake light came on. I pulled the ebrake 1/2 up and down a couple times but the light stayed on. Two blocks later the light went out on its own. As far as I know the brake light is and idication that the ebrake is on. Is it hooked to anything else?
Old Aug 24, 2011 | 12:12 AM
Steve2147's Avatar
Steve2147
Yes, it's also connected to the pressure differential switch in the proportioning valve. In a dual circuit brake system if there is a pressure difference noted between the frt and rear systems the light will come on. Usual cause of pressure diff is leak in one system.
Steve g
Old Aug 24, 2011 | 02:08 AM
couperdecar
thanks
Old Aug 24, 2011 | 02:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Time to inspect the brake system.
Old Aug 24, 2011 | 04:37 PM
...Roger...'s Avatar
...Roger...
Common cause of what you described, if you don't find any leaks,is the dreaded rotor runout.
Old Aug 24, 2011 | 04:55 PM
flaco1801's Avatar
flaco1801
check the fluid...you are low
To Brake Light Question
