need buying advice
Its a 1971 all original (exc radio but he does have the orig) matching numbers.
The bad (from our phone conversation):
paint is a 15 footer
AC blows a fuse
right side door handle needs work. must open from inside.
power steering hose leaks
its an auto
mileage is unknown
some gauges dont work
The good:
runs good
surface rust only
new interior
doesnt run hot
new tires
new rear sway bushings
its a driver/fixer upper which is what i am looking for.
its an auto
ok I am going to look at it Sunday. Any advice?
Whats the best way to inspect the birdcage?
most of the issues above I can handle. I can do electrical work and turn my own wrenches usually. I plan on a long term slow and easy restoration so I am trying to get the best bang for my buck.
I assume the suspension will need replacing but it sounds like he has at least done some of it.
How concerned would you be by the mileage issue. This is my first "old" car and I really am not sure how concerned I should be if it really is in decent shape.
I know it will probably need weather stripping and hoses and the usual stuff.
I am thinking if it is about what he says it is then its probably a $13000 car. I was asking 15 for the Jeep but was willing to take 14 so we are not far apart.
see the pile of rust flakes on top of the mount bolt?
here is one that is cleaner and in better shape
He says the only actual rust is some surface on the bolts.
The guy seems pretty straight up and has gone out of his way to tell me the faults. I am looking fwd to a closer inspection tomorrow.
If anyone is near Summit racing store in ATL tomorrow at 1 come by and say hello. we will be crawling over each others cars.
On my 71 Barn Find I was able to see rust easily when I looked down into the pillar area next to the windsheild and once removed it was a mess. I knew it but pulled the trigger and bought it anyway. The point is, my panels that you are looking at did give me a warning but not as much as smooping further around the windshield. My winshield area of my birdcage was shot. The panels are not always the best indicator, in my opinion and if you can look around the A-Pillar, windshield, etc. you can begin to see subtle signs if something is wrong. Mine didn't need to be subtle, they were more glaring, but you get my point. Be thorough and enjoy this car if and when you buy it.
If you want to follow my thread for more 71 tips you can find it here.
http://forums.corvetteforum.com/c3-g...barn-find.html
Best regards,
David
If it doesnt match it would be a red flag but not a deal killer for me. I'm certainly not looking for a trophy catcher or NCRS car. more of a driver fun timer but want the best bang/buck.
thanks!
Best regards,
David
This will give you some data on the features for 1971, and Corvette Black Book would give you even more data. If you need any assistance identifying data on the plate, engine block, etc. let me know or just ask here on the forum, lots of guys been down this road and would be glad to share.
David
I am going to pass on this one. just too many systems need work and I cant crunch the numbers to make sense. I would have to lowball his value and get a chunk of cash in addition. so much so it would probably insult him.
It was overheating when he got there throwing coolant on the ground
The paint was ok but had some gouges and faded pretty bad in back.
The AC compressor was popping the fuse
seats needed going over as the covers were not original. other interior things like door cards, ***** missing etc...
hard starting. carb needs adjusting, also the alternator or starting system needs going over.
smoking a bit so engine needed work
gauges need work, no idea what the mileage was. 29000 was showing.
some other things as well.
I was hoping for a mech sound car that needed some TLC. this was just too many systems needing work.
anyway thanks for the heads up guys. I learned a lot about what I need to look for in a C3. Maybe next time I'll find the right one.
Sounds to me that the seller is probably not too mechanically inclined, otherwise he'd have fixed most of the issues.
