Air Cleaner
Old Aug 30, 2011 | 08:39 AM
EngineerJay's Avatar
EngineerJay
Default Air Cleaner
I am looking to go back to my stock hood from the custom hood that is on the car. I have the hood, the only problem is someone put a different intake that is higher then normal. I was wondering if anyone knew of any low profile air cleaners that i could look into switching to.
Thanks,
Jay
Old Aug 30, 2011 | 09:58 AM
C3 Stroker's Avatar
C3 Stroker
There are drop base air cleaners similar to mine, made by Moroso, Proform, etc., or you could use a 2" element.
Mine......
Old Aug 30, 2011 | 10:52 AM
knockbill's Avatar
knockbill
i picked up a drop base a/c at carlisle, delco # 141-302, i needed just teh base, and put a pontiac type top on it for my 56,,, gets about an inch of clearance...
Old Aug 30, 2011 | 10:59 AM
ToniH's Avatar
ToniH
I am using the L88 drop base with K&N and crome lid.
Like this: Ecklers
Old Aug 30, 2011 | 11:38 AM
EngineerJay
I suppose I should have also mentioned the carb is an edelbrock with an electric choke, will these fit with the choke on the side?
Old Aug 30, 2011 | 12:16 PM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
I have one of these in very good condition that I'd be willing to part with
Its designed for lowprofile applications
Old Aug 30, 2011 | 02:14 PM
knockbill's Avatar
knockbill
[QUOTE=C3 Stroker;1578558491]There are drop base air cleaners similar to mine, made by Moroso, Proform, etc., or you could use a 2" element.
do you have a part number for a 2" element? i'd like to try one...
thanks
Old Aug 30, 2011 | 03:08 PM
Vette5.5's Avatar
Vette5.5
Best bet is getting a stock housing(doesn't need to be from a Vette) putting in some ovaled 4" collars, and running flex hosing to in front of the radiator housing for fresh air. Probably one the best mods you can do, for cruising on hot summer days. Maybe even bump flex hose size down a bit if needing to.
Old Aug 30, 2011 | 03:33 PM
Ganey's Avatar
Ganey
You will probably need another intake for stock BB hood.
I run Holleys, have an Edelbrock catalog & had noticed NOTE for Edelbrock carbs. below so it will be a little higher than w/ Holley.
http://www.edelbrock.com/automotive_...c_chrome.shtml
NOTE: #1207 is stock height and requires spacer #8092 with electric choke carbs or banjo fitting #8089 with manual choke carbs. #1221 fits all Edelbrock square-bore carbs and Q-jets (3/8" taller than #1207).
Old Aug 30, 2011 | 03:53 PM
Ganey's Avatar
Ganey
thanks
Do you think a 2.3"x14 would work for you?
Old Aug 30, 2011 | 04:19 PM
C3 Stroker's Avatar
C3 Stroker
[QUOTE=knockbill;1578560793]
thanks
Here's one...
http://www.summitracing.com/parts/MRG-1480A/
Old Aug 30, 2011 | 04:58 PM
knockbill's Avatar
knockbill
I found a mr gasket 2" x 14" (#1480a), looking to cross reference it to something napa, (or others), may have in stock...
but at least its out there!!
Old Aug 31, 2011 | 04:36 PM
couperdecar's Avatar
couperdecar
Thanks,
Jay
No offense - but don't blame you for wanting to go back - That hood is like 'Corvette Summer'.
To Air Cleaner
