poly bushings?
Old Sep 1, 2011 | 12:03 PM
Sunstroked's Avatar
Sunstroked
Default poly bushings?
How many of you C3 owners have put the polyurethane bushings in your control arms and noticed any difference compared to a rubber bushing that was not worn out?
I'm trying to make up my mind on my front end rebuild of my 72. I have a complete front end rebuild kit for it that came with the car when I bought it. I'm upgrading to a VB&P grand touring suspension system with the bilstein shocks. I also opted for the rubber rear trailing arm attach bushings as well as the differential crossmember mounts. I'll install the poly in the sway bars, shocks, and lower differential mount.
I want the car to have a smoother, softer ride compared to my 92 that has an aggressive sport suspension. When I'm out cruising with the wife, she really notice's the stiffness and firm ride. I love it when I'm driving the corners aggressively by myself. But the 72 is going to be a club cruiser/show car. I'm keeping the stock 15" wheels, probably put some BFG radial TA's on it. I love the stock look and is my theme for this car. Its so classic.
Opinions please.
Old Sep 1, 2011 | 12:55 PM
Spot Rot's Avatar
Spot Rot
Every time I've installed poly bushings, they eventually sqeaked loudly and I went back to rubber.
Of course, the manufacturer claimed their poly never squeaks.
If you don't drive your car much, or don't care about the noise, or the rougher ride - and you believe they'll make your C3 handle like a newer Corvette, give them a try.
IMHO: A better set of tires does more than all possible mods combined.
Old Sep 1, 2011 | 01:10 PM
StingrayLust's Avatar
StingrayLust
Default they'll hear you coming from miles away
I'm in the middle of doing my front suspension and went with rubber because I didn't want a rougher ride, it's a cruiser like yours. Now for some, poly may never squeak or they've added some grease zerks in some fashion, but take a look at this video.
Old Sep 1, 2011 | 01:22 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I replaced all of the bushings (front and rear) in my 82 with poly - no squeaks. It still feels softer than my Z51 equipped C6.
Old Sep 1, 2011 | 01:56 PM
Joe Buck's Avatar
Joe Buck
Did a full replacement and it made a very big difference, though my original rubbers were all worn out anyway.
Even after greasing I have a noticeable squeak when going over speed bumps, though they do dissipate/become non-existent after the first 20 minutes or so and she's warmed up.
Old Sep 1, 2011 | 02:27 PM
63split63's Avatar
63split63
Default Just Removed Mine
I just removed the polly bushings from my upper controll arms on my 71. I will do the lowers this winter. They squeaked and rattled like hell.
Bill
Old Sep 1, 2011 | 02:40 PM
1nicecorvette's Avatar
1nicecorvette
did poly in the front and in the rear strut bars havnt got to the rear control arms yet. stiffer ride plenty of lube and no squeeks.
Old Sep 1, 2011 | 04:41 PM
Rebelrob's Avatar
Rebelrob
Haaa, I like that video, you cannot argue with his issue.
I installed rubber recently to my front end as well. Figured the originals lasted at least 20 years and did not want to risk the squeak or rougher ride. I already got 550 springs, so its rough enough.
Old Sep 1, 2011 | 05:04 PM
DRIVESHAFT's Avatar
DRIVESHAFT
What? I didnt hear anything...
Old Sep 1, 2011 | 08:38 PM
Sunstroked's Avatar
Sunstroked
You know that video just made up my mind. Thanks.
Old Sep 1, 2011 | 09:52 PM
my 76 ray's Avatar
my 76 ray
One of the manufacturers' web sites says that the black poly has graphite impregnated in it. Since some say their poly bushings don't squeak, I'm wondering if the black ones don't squeak. Nobody ever says what color theirs are.
Old Sep 1, 2011 | 10:37 PM
Tally Ho's Avatar
Tally Ho
Mine are black. No squeaks.
Old Sep 1, 2011 | 10:48 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Poly isn't for everyone, but neither is rubber.
It really depends on one's priorities and where it is being considered as to whether it makes sense or not. Proper installation and lube should keep it from squeaking, which is evidence of binding. Suggest shopping for those with serrated sleeves, as the smooth ones tend to loosen. My $.02, free of charge.
Old Sep 2, 2011 | 06:37 AM
Danish Shark's Avatar
Danish Shark
Mine are black, after two years one side now squeaks so much that it has become unbearable.
When I installed them I basically drowned them in lube (silicone) so no matter what you do poly bushings in moving parts will eventually squeak.
And it takes a lot more than poly bushings to turn a C3 into anything resembling a hard ride!
Old Sep 2, 2011 | 08:37 AM
ToniH's Avatar
ToniH
Mine are black and have been in the car for 7+ years. No squeaks. I think I used waterproof grease I bought from a boat shop.
Old Sep 2, 2011 | 11:13 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
my poly bushings are really stiff.....i wish i had used rubber
Old Sep 2, 2011 | 12:20 PM
Sunstroked's Avatar
Sunstroked
Like I said, I love the slot car handling of my 92. It has poly. I've been working on jet aircraft for the past 28 yrs, my high pitch hearing is shot, so if it squeaks, I can't tell. My priorities are different with this car. I think most of the responses leaned toward using rubber and that's where I'm leaning. Thanks folks.
To poly bushings?
Old Sep 2, 2011 | 02:19 PM
builder's Avatar
builder
Originally Posted by Sunstroked
....... my high pitch hearing is shot, so if it squeaks, I can't tell. ........
I have my bride to let me know when things rattle and squeak. If I can't hear it, I tell her that it's supposed to be that way.
Old Sep 3, 2011 | 01:29 AM
Sunstroked's Avatar
Sunstroked
That is so true. My wife does the same, she will hear sounds that I never will be able to. But.... put me in the elk woods, I'll hear an elk bugle a mile away. She calls it selective hearing.
Old Sep 3, 2011 | 11:11 AM
Spot Rot's Avatar
Spot Rot
So all the people whose poly bushings squeak installed them improperly or lubed them improperly?
I'm surprised you had the time to visit and inspect all those installations.
