C-3 race car console pics
Old Sep 1, 2011 | 12:16 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default C-3 race car console pics
Would like to see some pics of the console area of old (or new) C-3 race cars. I know some cars had a series of electrical switches mounted in the console area.
Thanks,
Rex
Old Sep 1, 2011 | 01:31 PM
lvrpool32's Avatar
lvrpool32
http://corvetterepair.com/portfolio/ click on C3 lots of interior shots from the racecars (just click on each of the cars)
Old Sep 1, 2011 | 02:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Try Google Images.
Old Sep 1, 2011 | 08:35 PM
Dr L-88's Avatar
Dr L-88
Thanks guys, that's what I was looking for.
Rex
Old Sep 2, 2011 | 07:40 AM
stingr4y's Avatar
stingr4y
I'm interested in your project.
Can you keep us posted?
Old Sep 2, 2011 | 01:54 PM
Dr L-88's Avatar
Dr L-88
Will do. It's in the works as I write this.
Rex
Old Sep 6, 2011 | 09:32 PM
Dr L-88's Avatar
Dr L-88
Here's the first draft, nothing fancy, just basic instruments. Two versions. The one with 3 gauges at top would have a series of "yet-undetermined" toggle switches. Not sure whether it would look better in raw aluminum, lightly glass beaded aluminum, or just painted flat black.
Thoughts, ideas, suggestions?
Thanks,
Rex
Old Sep 7, 2011 | 08:22 AM
bjm's Avatar
bjm
I would always want the Oil Pressure gauge in the most visible spot if it were a race car, but if it is just for a street car I guess it is not as important. It looks blocked from view by the shifter. Just a thought!
Old Sep 7, 2011 | 10:23 PM
3JsVette's Avatar
3JsVette
Rex I think either version looks good. The finish I would lean towards would be raw aluminum as it is probably more period correct (if that's the look you are after). If that is the look you're after do the "push in" fuses work or should they be the glass tube type? I'm not trying to be a smart a$$ but I know how you strive for authenticity.
Old Sep 7, 2011 | 11:21 PM
bkvette3's Avatar
bkvette3
The raw aluminum version with the toggle switches on the top looks KILLER. That would be my pick. Nicely done.
Old Sep 8, 2011 | 03:53 AM
stavanger's Avatar
stavanger
Old Sep 8, 2011 | 07:11 AM
stingr4y's Avatar
stingr4y
I love both especially the first one.
Black might be the more authentic choice as it cuts down on glare, but aluminum looks pretty utilitarian cool.
My first homemade dash was raw aluminum, but I wound up painting it for that reason.
You're making me want to redo mine with some original panels and trim.
It's pretty plain right now.
Old Sep 8, 2011 | 08:31 AM
lvrpool32's Avatar
lvrpool32
I woud go black, maybe even look into powder coating as that would stand up a little better. The other thing is ergonomics...if you look at where you have the switch's in the first one, will you be able to reach them, strapped into the seat? When I did mine I couldn't reach (shifter into first was the furthest forward I could reach), so I put my switches down the side of the plate and used toggle switch extensions.
Nick
Old Sep 8, 2011 | 10:49 AM
tyancey00's Avatar
tyancey00
Originally Posted by stavanger
holy ****!! i would be scared to death if you picked me up hitchhiking!! But i would get in just the same!!
Old Sep 8, 2011 | 04:25 PM
tekvette's Avatar
tekvette
Very very nicely done. I am definately impressed. Nice job!
Old Sep 8, 2011 | 04:48 PM
lvrpool32's Avatar
lvrpool32
Thats the interior of the #12 Owens Corning car restored by Kevin Mackay and Corvette Repair.
Old Sep 8, 2011 | 08:17 PM
Dr L-88's Avatar
Dr L-88
Thanks for everyone's input, I DO value your opinions, that's why I posted here. As of tonight, I am leaning toward the setup with the 3 gauges at the top, slightly rearranged in this photo with the oil pressure gauge moved to a more viewable position (thanks BJM for pointing that out). A push button starter switch would be located either between the oil pressure and water temp gauges or just to the left of the oil temp gauge. I'm just not sure about the 3 red toggle switches, I may just use plain toggle switches, maybe 3 or 4, one each for driving lights, fuel pump and cooling fans. In the first pic the shifter is in 1st gear and second pic it is in 4th gear (opening for shifter has not been fully finished yet). Even though I like the arrangement of toggle switches in the other layout, the Quickcar panel just seems a bit too modern looking. Actually, these SW gauges are old and the numbers are slightly yellowed, thus adding some patina. Also, this aluminum, when lightly glass beaded and then coated with a low gloss clear looks killer. What do you think? And yes, I am entirely open to suggestions.
Thanks,
Rex
To C-3 race car console pics
Old Sep 9, 2011 | 05:30 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Have you thought about using these angle mounting rings behind the gauges to tilt them for possibly better viewing?
http://http://www.summitracing.com/parts/ATM-3244/?rtype=10
Old Sep 9, 2011 | 06:30 AM
parkerracing's Avatar
parkerracing
You want to keep your gauges in line of sight. Looking down while racing isn't such a good idea. Here's what the Greenwood racers look like.
Old Sep 9, 2011 | 11:14 AM
Dr L-88's Avatar
Dr L-88
I did not know these existed, but I had considered attempting to fabricate something like this for that very purpose. Thanks for pointing these out Jason!!
Rex
