First Timer: Front Suspension and Steering upgrade
Old Sep 1, 2011 | 05:05 PM
silver79's Avatar
silver79
Default First Timer: Front Suspension and Steering upgrade
I am going to try to install my VB's rack and pinion myself, I have tools and I think I am pretty handy with my hands. I also have U tube and the Hayes Corvette repair manual.
I was told that the upper and lower ball joints have to be changed, they are the ones that come with VB upper and lower tube A arms (they where installed in 2004) I will do that at the same time.
How hard do you think this would be to do?
I will post pictures as I go along, so I will need your help but most important your Support
Old Sep 1, 2011 | 07:52 PM
mn_leaf_fan's Avatar
mn_leaf_fan
I'll be following this thread closely... I have the the same parts sitting in boxes waiting for me to work up the nerve to start.
( and for the garage to get cooler too )
Old Sep 1, 2011 | 09:05 PM
72LS1Vette's Avatar
72LS1Vette
Dismantling the front suspension is something you can find in the service manual or from a search of the forum. If your ball joints are original you will have to grind off the rivet heads to remove them. I would replace the lower ball joints while I was at it. Also inspect the control arm bushings to see if they need replacement.
Kits don't always fit as advertised so you may have to do some grinding, etc. to get things to fit right. VB&P is a quality vendor but your particular car may still have fitment issues.
Rick B.
Old Sep 2, 2011 | 05:37 PM
silver79's Avatar
silver79
Success I did it after 2 hours of battling bolts, tight places and grease I removed the steering system in one piece, Not bad for a first timer.
This Sunday I will clean and get every thing ready for the install.
One question how do I tell if the ball joints need changing?
Old Sep 4, 2011 | 10:11 AM
silver79's Avatar
silver79
So taday the prep starts. Will wash and detail everything. Then start to re-install the rack. Might change the setting of the front sting one notch stiffer.
Old Sep 4, 2011 | 02:30 PM
Rebelrob's Avatar
Rebelrob
Good job... keep it up.
I like your paint color and wheels. Looks good.
Old Sep 5, 2011 | 08:59 PM
silver79's Avatar
silver79
Thanks Rob, I love the color too and I really like the 82 collector wheels with knock offs
Old Sep 5, 2011 | 09:06 PM
silver79's Avatar
silver79
Finally the rack is up , way more than 3 hours, with bolts in very tight places. No problem removing them all none were seized. I will finish it then I will poist my impression of the new steering system, it should be a great upgrade.
Some questions I have, how do I drain the power steering bump?
Old Sep 5, 2011 | 09:08 PM
silver79's Avatar
silver79
One thing that i really hate is how the frame gets all dented from the jacks stands, what do you guys do to remedy that?
Old Sep 7, 2011 | 03:16 PM
sakins.02vert's Avatar
sakins.02vert
Wow, great work and thanks for the pictures.
Old Sep 7, 2011 | 04:10 PM
Dose11's Avatar
Dose11
Have you taken her out yet? How's the upgrade?
Old Sep 7, 2011 | 06:16 PM
silver79's Avatar
silver79
No not yet I will finish painting the calipers (red), change the oil and also install a ball valve to cut the cabin heat. I have an appointment tomorrow for the alignment. I am excited to go for a ride.
keep you posted with pictures later.
Old Sep 7, 2011 | 06:27 PM
Sam and Jess's Avatar
Sam and Jess
Nice work... I am considering this upgrade. Be sure to fill us in on how the car turns. I am also curious of the actual steering feel/feedback. --Sam
Old Sep 7, 2011 | 10:01 PM
silver79's Avatar
silver79
Well, like i suspected the ball joints are done there is quite a bit of movement on the bottom of the front wheels when I hold them at 4 and 8 o'clock. I wonder if I have to get the front end aligned after a ball joint replacement???
So this is the calipers painted red
and here is the universal joint attached to the steering shaft, I am going to send this picture VB to is if there is to much thread showing at the attachments.
To First Timer: Front Suspension and Steering upgrade
