need help with part name
Old Sep 1, 2011 | 08:02 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default need help with part name
can anyone please tell me what this part is called. it is on the left side of the carb on my 78 l82 and it's purpose is to pop out and increase the idle when the a/c is on. it is one is sticking so i think i need to get a new one if it is available. i just need to know the proper name so i can look it up in a catalog. thanks.....
Old Sep 1, 2011 | 08:07 PM
'75's Avatar
'75
Idle stop solenoid or idle control solenoid
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Sep 1, 2011 | 08:08 PM
markids77's Avatar
markids77
I always called them the anti-diesel solenoid... might have a dual purpose though.
Old Sep 1, 2011 | 08:15 PM
'75's Avatar
'75
Sticking? Is it keeping the idle up when the AC is off?
Old Sep 1, 2011 | 08:18 PM
hdff's Avatar
hdff
no when i turn the a/c on it will not pop up to increase idle without a little persuation
Old Sep 1, 2011 | 08:20 PM
'75's Avatar
'75
Those typically don't have enough power to push the throttle up alone. You have to push the accelerator, then the solenoid will hold it up.
Old Sep 1, 2011 | 09:41 PM
hdff's Avatar
hdff
thanks. if when it does come up the idle is to high do i just screw the end in to get the right idle. also it looks like a cover is missing on the front end, any thoughts?
Old Sep 2, 2011 | 05:03 PM
'75's Avatar
'75
Yes, just screw the bolt end in to lower the idle. The cover missing shouldn't hurt any thing.
Old Sep 2, 2011 | 07:26 PM
thegazman's Avatar
thegazman
Default thegazman
To need help with part name
