does any one like ethanol?
before the address of any other website, voila Bacongoogle:
http://bacolicio.us/http://www.google.com/
Have fun................Keats
Scott
As far as ethanol in my cars, I'd prefer not to. I don't think it will cause any damage, but it is definitely a waste of resources at a time when this country needs to be getting smarter with its resources, not dumber.
The water used to create Ethanol is recoverable.
After Ethanol is removed from the corn, the leftover corn byproduct is used for livestock feed. It is not waste. It is actually feed for livestock. It is not thrown away.
10% ethanol will not kill your bronco's fuel injected engine, "Most" of the problems with carburetors and such is caused by "Methanol", not Ethanol. Methanol is found in gasoline dryers like "HEET".
I have been using Ethanol for 30 years consistently in lawn mowers, cars, trucks, etc. I have run it in "almost" every vehicle I have driven for any length of time. I remember one instance where it swelled the carb seal on my old Bendix carburetor. I went back to the station where I got the gas and it was labeled "Methanol". That was 30 years ago.
Yes, mileage will go down, but, in most cases, the mileage is a break even deal because of the lower costs of the fuel. Broin industries is now producing corn oil from the same byproducts, to be used in bio-deisel fuels. Thus, producing more fuel per bushel yet.
Ethanol is here to stay. They are now working on using prairie grasses also. It produces a better grade of Ethanol, more Ethanol, and the grasses can grow on poor soils and needs no chemicals to produce. Ethanol is not bad. I'm sure that farmers like the benefits of getting something for their corn too. They have been shafted for decades by low corn prices.
Bad mouth Ethanol all you want, but do a little more research before you do. It also helps keep oil prices down.
Your corn based foods are more expensive? Compared to what?
Old way of thinking: Corn = food and feed
New way of thinking: Corn = food, feed, ethanol, bio-diesel, a multitude of other corn byproducts, jobs, community growth, lower oil prices, cleaner burning engines, automatic moisture displacement in fuel storage, deicer for roads in the snow belt, research to better Ethanol sources, and more.
I also consider myself quite ignorant of Ethanol uses and research. This is just a peripheral knowledge of corn based Ethanol.
That is why Ruggles went to lengths to make his own ethanol resistant pump assemblies.
I don't know of any issues with electronic fuel injection.
The real issue here is what do we think of ethanol and that it's a total waste of our resources. It takes almost as much energy to produce a gallon of ethanol as ethanol delivers. And that's not including the fact that you have to truck ethonal because it can't go in pipelines.
Mark
In the earlier days of "alcohol" mixed with gasoline, some companies used Methanol in the gas. Methanol has probably disappeared from gasoline by now (I don't know that for sure). I was telling you of a circumstance that happened 30 years ago.
Marks76ray - You don't have to get on my band wagon.
People have the right to be "myth"informed. After four months of sitting your fuel was rotten? I have a fuel injected truck that sat for 8 years with ethanol in the tank, and I ran a full tank (34 gallons) of smelly gas through the thing. I drive it all the time. Fuel pumps go bad. Rubber fuel lines go bad. These things happen all the time from the beginning of time. It's common.
So you had your Bronco fixed and were told it was the ethanol, You didn't run it anymore. Fine. Believe it. Your problem is solved. But, how do you explain the "millions" of fuel injected cars that run it every day without it screwing them up?
Politically, I am still on the fence about ethanol subsidies. I'm not sold on all aspects. I think we could save more money addressing people who live their whole lives on Welfare than we could on Ethanol production.
But it was definitely a premature death due to ETHANOL this stuff stinks when it sits up for 4 months.
