Fan clutch went--
Old Sep 9, 2011 | 07:53 PM
slewfoot1956's Avatar
slewfoot1956
St. Jude Donor '14
Default Fan clutch went--
This morning i started it up with a a heck of an instant noise and then nothing. Popped the hood with the engine still running and noticed the fan not spinning so I assume this is the problem
I am not "shop setup" choice but I have good mechanical skills. Replaced the fuel pimp and a few other things. Most stuff ihave a mechanic do.
Is replacing this thing a pita or not a big deal?
82-350ci
Old Sep 9, 2011 | 08:58 PM
...Roger...'s Avatar
...Roger...
Not a bad job,check the water pump for play.
Old Sep 10, 2011 | 02:43 AM
JohnnyLT1Runner's Avatar
JohnnyLT1Runner
I wish I had a fuel pimp, gas would be cheaper that way.
Old Sep 10, 2011 | 07:36 AM
Mike Ward's Avatar
Mike Ward
A bad clutch will not stop the fan from spinning. Best keep looking to see what's blocking it.
Old Sep 10, 2011 | 11:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I usually skin a knuckle when removing the fan. Not sure if that's my fault, or if fans hate me. I suspect it's the latter.
Old Sep 10, 2011 | 11:54 AM
...Roger...
Mike , you need a longer handle on your 1/2" wrench.
Old Sep 10, 2011 | 12:03 PM
killain's Avatar
killain
Oldtimer
Default Fan Clutch R&R
I had to take the fan and the fan shroud out as a unit in my 79 ! Not impossible, about a 2.5 hour job. It helps a lot if there are two of you easing the two pieces out. My brother in law helped with the taking out and easing the thing back in. Like mentioned above, great time to check that the water pump is OK as you have an excellent view of it with the fan and shroud is out of the way.
Old Sep 10, 2011 | 12:11 PM
Easy Mike's Avatar
Easy Mike
Or smaller knuckles.
Old Sep 13, 2011 | 05:17 AM
hunt4cleanair's Avatar
hunt4cleanair
I've pulled my fan clutch enroute to removing radiator and while sitting, oil appeared from the clutch. Is it going?
Old Sep 13, 2011 | 06:23 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
It takes about 45 minutes to get the fan out. Approach it from the passenger side. The trick is to unbolt it from the water pump after first backing off the fan belts. THere are studs holding it on and sometimes they come out with the nut. While it is out, check the operation of the electric fan on the radiator. I was really surprised to see one there. It is controlled by the sensor on the passenger side right above the starter. 2 simple wires. One is current *hot* so be careful. The fan comes on at 280-300. I just hooked up a car battery to a test lead and the fan came on. Paint the fan and clutch while you have it out. Grab the water pump shaft and, as mentioned, check for leaks and play. Replace all the belts while you have it out. You will be glad later. Really not that bad of a job.
It's spinning here but you can get the idea.
Old Sep 13, 2011 | 10:01 AM
builder's Avatar
builder
I can't see why you would have to remove that PITA fan shroud to replace the clutch. It's simple enough.
Old Sep 13, 2011 | 10:15 AM
tyancey00's Avatar
tyancey00
was the fan laying down? it should always stand up so the oil does not run out...
Old Sep 13, 2011 | 10:16 AM
...Roger...
Should be seal side up.
Old Sep 13, 2011 | 10:19 AM
rdroe's Avatar
rdroe
Default Fan Clutch
It does make sense, now that I think about the concept of the clutch fan, that there would be some sort of oil in it. I know that there is a temperature sensing coil on the outside that faces the radiator. The strange thing is, when I had mine all apart ... fan clutch separate from the fan, separate from the pulley, I never paid any attention to orientation, etc. I just treated it as another part on the bench. I cleaned it, painted it, did NOT handle it with care. Maybe I was lucky. Are they fragile?
Old Sep 13, 2011 | 10:21 AM
...Roger...
Some of you are making a much bigger deal of changing a fan clutch than should be.
Here is what the 82 manual says:
Remove neg batt cable at battery.
Remove air cleaner intake duct.
Remove fan clutch to water pump hub attaching bolts or nuts,as applicable,and remove fan clutch assembly.
The factory R&R time is .6 hours.
Old Sep 13, 2011 | 10:39 AM
bashcraft's Avatar
bashcraft
Make sure that the fanbelt just didn't break, or maybe just come off.
Old Sep 14, 2011 | 03:52 AM
hunt4cleanair
Yes. Seems ok now but than the oil may have run out but its still stiff when rotating blades with shaft held still
To Fan clutch went--
Old Sep 14, 2011 | 11:40 AM
builder's Avatar
builder
So, when you go to the parts house to get another one, do they guarantee that it was shipped and stocked on the shelf in the correct position?
I don't think the should be leaking.
Old Sep 14, 2011 | 03:13 PM
Easy Mike's Avatar
Easy Mike
...Remove fan clutch to water pump hub attaching bolts or nuts,as applicable,and remove fan clutch assembly...
It is at this step, I skin a knuckle.
...The factory R&R time is .6 hours...
The .6 hours does not include me hopping around all over the place, screaming vile and hateful things, wringing my busted knuckle (that never works, but it somehow makes me feel better), and licking it long enough to get into the house for a band-aid. Add ten minutes for that.
Band-aid in place, I return to the shop somewhat comforted by the FCB I have removed from the fridge and brought with me -- I mean, geez, I was walking right past the fridge anyhoo, so why not? Right? Knuckle still stings a little. I remember hearing the wrench when it hit something, but I am not certain in which direction I threw it. My eyes were shut in pain at the time I launched it. And - day-umm- it was my favorite 1/2 too. Not the lousy one I've been threatening to throw away, but my favorite. Add half an hour to sit down and sip the FCB, some of it anyway, and see if I can see where the wrench landed.
Knuckle not stinging anymore, wrench showed up, but I still don't have the fan off.
Old Sep 14, 2011 | 08:58 PM
...Roger...
ouch,maybe when should pass the hat and get you a pair of gloves.
