Drivers seat latch
Old Sep 11, 2011 | 12:40 PM
pawpaws toy's Avatar
pawpaws toy
Default Drivers seat latch
My 1980 seat back locked up and won't tilt forward. Is there a hidden latch somewere I'm not seeing? This just happened now and never in the past.
Old Sep 11, 2011 | 02:05 PM
gbvette62's Avatar
gbvette62
There's no hidden latch on the seat, only an inertia latch, installed in the hinge itself.
This is actually a pretty common problem. I have the same problem with my 81. The drivers side seat back has never locked up, but the passenger side one has done it occasionally, almost since the car was new.
The inertia latch is in the outside hinge of the drivers side seat. I've found that by sliding a long thin screw driver into the hinge, you can release the latch. I forget exactly where you release it and I can't get to my 81 at the moment, but if you do a Forum search, you should find some help with the latch, as it's been discussed in the past.
Old Sep 11, 2011 | 02:11 PM
pawpaws toy
Thanks so much. Did as you said and everything is OK now.
Old Sep 11, 2011 | 02:49 PM
gbvette62's Avatar
gbvette62
That's good to hear. I always leave a screw driver in the rear storage compartment, in case it locks up when I'm out somewhere.
To Drivers seat latch
