1968 Smog
Old Sep 13, 2011 | 01:48 AM
13611's Avatar
13611
Default 1968 Smog
Were all 1968 327/300hp Vettes equiped with a smog pump? If some were and some weren't, how can I find out if the one I'm restoring had one? Thanks, Jason
Old Sep 13, 2011 | 02:22 AM
vettebuyer6369's Avatar
vettebuyer6369
All 68 and 69 Corvettes were equipped with A.I.R. systems.
1968 pumps had part number 7801135. The '68 is different from '69s (except some early '69 units) in that they had the visable pressure relief valves on the top of the case.
Old Sep 13, 2011 | 09:51 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
You can still get replacements at Rockauto.com. Not a perfect NCRS replacement, but good enough.
Old Sep 13, 2011 | 11:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
AIM pages show 19000. That means all cars, coupe or convertible, big block or small, got the AIR stuff.
Old Sep 13, 2011 | 07:11 PM
vettebuyer6369
Sounds a lot like what I said.
Old Sep 13, 2011 | 09:45 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
.....also, if I'm remembering correctly, all '69 L-88s used the '68 style A.I.R. pump for whatever reason.
Old Sep 14, 2011 | 07:46 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Hey Steve, where is that part #?(7801135)
I know they were all cast with 7801149 on the rear of the pump right? That number was used well in to the 70's. I'll have to check mine when I get home but I could have sworn it's a 1149.
Old Sep 14, 2011 | 11:17 PM
vettebuyer6369
The 1149 cast is on the backside and is found on a lot of pumps including non-Corvettes if I remember right.
1135 is found under the fan, as is 5650 for '69.
Old Sep 15, 2011 | 12:01 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
gotcha, thanks
Old Sep 15, 2011 | 10:32 AM
Easy Mike's Avatar
Easy Mike
We were typing together. Obvioiusly, you had had a bit more coffee than me and were quicker on the draw.
Old Sep 15, 2011 | 04:33 PM
vettebuyer6369
LLLottts o coffeee
Old Sep 16, 2011 | 06:58 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
.............& the 68's had white fan fins.............
To 1968 Smog
