Tach Question.....
Old Sep 13, 2011 | 07:18 PM
Richard Cooper's Avatar
Richard Cooper
Default Tach Question.....
Should I have 12 V coming from the wire on the distributer marked "tach"? I took my distributer cap off to check something and now my tach does not work. The tach needle gose to10 when the car is shut off and goes to 0 when the car is started. I eliminated the filter just to see if it would work, but does not. TIA
Old Sep 14, 2011 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked to ensure you have the tach terminal plugged in well on the distributor. Mine gets loose periodically.
Old Sep 14, 2011 | 11:34 AM
Richard Cooper
I have removed the wire several times to make sure its attached well. I even sprayed some contact cleaner on both the wire and the terminal it plugs into. Do you have 12V at the terminal on the distributor? If I am supposed to have 12 V there and do not then I know its something inside the cap. Oh, and by the way, thank you.
Old Sep 14, 2011 | 10:33 PM
Richard Cooper
Anyone.....
Old Sep 15, 2011 | 10:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The signal wire should never have 12 volts on it.. you might check the coil in the distributor cap and see if the terminals are touching.. or the coil may be defective.
Old Sep 16, 2011 | 09:58 AM
Richard Cooper
Once again, THANK YOU WILCOX.
Old Sep 17, 2011 | 12:05 AM
0Willcox Corvette
Former Vendor
Not a problem Richard.. I've got a few tachs under my belt..
To Tach Question.....
