install new outer window seal
Old Sep 15, 2011 | 02:26 PM
corvald's Avatar
corvald
Default install new outer window seal
Hello.
Is it possible to remove the old outer window seal, and install the new with the window in the door, or must i remove the window?
Old Sep 15, 2011 | 02:48 PM
Roco71's Avatar
Roco71
I believe the glass has to come out.
Old Sep 15, 2011 | 02:59 PM
lvmyvt76's Avatar
lvmyvt76
I did mine with the window in, took off the inner panel, took the 2 screws out of the door weatherstrip ends , took the end screws out the outer seals and pop the old seals out. Reverse to install new seals.
Old Sep 15, 2011 | 03:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You might be able to move the lower stops in the window channels and let the door glass ease down below the top edge of the door.
Old Sep 15, 2011 | 03:06 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Funny thing about this.. I just helped them do this in the shop yesterday...
Old Sep 15, 2011 | 03:08 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Loosen or remove the two felt covered brackets (the official name escapes me) on top after removing the door panel. that will let the window move to the inside of the door enough to easily R&R the outer felts. Just put them back the way they came out or the window will either rattle or be very slow while operating.
Old Sep 15, 2011 | 03:22 PM
corvald's Avatar
corvald
Oh, that was fast answers, thanks to all
corvald
Old Sep 15, 2011 | 04:51 PM
Roco71's Avatar
Roco71
I bet your glad you didn't listen to me.
To install new outer window seal
