C3 LOCKED !!! Help!!!
Old Sep 21, 2011 | 02:22 PM
builder's Avatar
builder
Default C3 LOCKED !!! Help!!!
Do you guys know of an easy way to unlock my C3? I had new keys made but didn't test them in the doors first. Any easy ways I can open it?
Old Sep 21, 2011 | 02:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Still have the old keys?
Old Sep 21, 2011 | 03:00 PM
beachcomber's Avatar
beachcomber
Big rock?
If you can't get in and don't have the original keys, a locksmith is your best option at around $70. That's the price I paid a few years ago on an old Mustang.
Good luck!!
Old Sep 21, 2011 | 03:13 PM
Dose11's Avatar
Dose11
Old Sep 21, 2011 | 04:02 PM
VISLEGIS's Avatar
VISLEGIS
Do you have a coupe? I have read on a past thread that banging on the T-tops can sometimes cause them to unlatch.
Old Sep 21, 2011 | 04:09 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by VISLEGIS
...I have read on a past thread that banging on the T-tops can sometimes cause them to unlatch...
I actually winced when I read that.
Old Sep 21, 2011 | 04:10 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I locked my keys in my 76 one night stopping for dinner with friends after a car show. I pounded on the T-Tops at each latch location and one lock on the passenger side popped open. I was able to get enough play to release the 2nd latch. I just used the ball of my hand - nothing too hard.
Good luck.
John
Old Sep 21, 2011 | 04:16 PM
...Roger...'s Avatar
...Roger...
Builder-I sent you a PM with a video but for some reason the text that goes with it disappeared.
If any of you guys still have this vid with text , please send it to me so I don't have to write it over. Thanks
Old Sep 21, 2011 | 04:46 PM
PhilaScott's Avatar
PhilaScott
are you locked in or out?
Old Sep 21, 2011 | 04:59 PM
builder's Avatar
builder
I got it. Thanks All. Especially PhilaScott. After I realized I was on the inside looking at the rear view mirror, it became clear.
Old Sep 21, 2011 | 09:19 PM
DZRick's Avatar
DZRick
Old Sep 22, 2011 | 12:52 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Good luck.
John
This works great unless you have tight fitting t-top latches, which in that case (like my car) it wont ever work
Old Sep 22, 2011 | 12:14 PM
Wrecked82's Avatar
Wrecked82
If you can pop your t-tops like that, they must leak in the rain. But, if you can, you better get some locks and thieves know this trick also.
Old Sep 22, 2011 | 05:28 PM
Stoge's Avatar
Stoge
Being the owner of a broken glass top and remembering how difficult it was to find a replacement original M1131 top, I winced a few times when reading that.
A fiberglass top, bang away. If its glass, get a locksmith. Heck, get a coat hanger and mar up your weatherstripping. Either is cheaper and easier than finding original glass.
Old Sep 23, 2011 | 12:59 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 69 car has the shields over the door lock rod.. If the vid Roger posted doesn't work out you could try a slim Jim.. I've done this before and it just involves knowing where the lock pawl is positioned. But if the shields are still in the door then you won't be able to get to the lock pawl with a slim jim.
Old Sep 28, 2011 | 02:06 PM
builder's Avatar
builder
The reason I was frantic about it was that I had an appointment that I didn't want to miss, and I was leaving for a weekend driving vacation. I was about 10 minutes late for my appointment and all worked out OK.
I had been working on the car putting in carpet, seats, engine, trans, rear end, axles, brakes, etc. and getting it ready to be mechanically sound to drive for the trip. The date got moved up for me to go (don't ask me if that had anything to do with the better half). One of the things I didn't get to was to remove the door panels and to at least check out the insides of the doors. I probably would have had better luck with a Slim Jim if I had. I made sure that the original key was on my key chain before we left. The original key opens the door smooth as silk. After comparing the keys, they look cut very well, but, the new key is thicker on the tumbler tooth side. I'll have to take them back to see if the locksmith can fix this.
P.S. My gal sure had fun driving the car too. She didn't give me the second set of keys yet.
Old Mar 31, 2012 | 04:15 PM
Lyonmaster's Avatar
Lyonmaster
Cruising
Good luck.
John
Thanks this worked, locked my keys in my 82. Gave up on the coat hanger, it was eating up my weather stripping.
Old Mar 31, 2012 | 06:08 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
What year is this? My 1980 has the locks in the armrest and there is no way I hanger would be able to pull it up.
As for the pounding on the ttop, +3 for cringing when reading this. It wouldn't work for mine as they are tight, but if they are loose enough to do this, then I say you need to tighten them or replace them before some guy decides to give it try too.
Old Apr 1, 2012 | 10:31 AM
Lyonmaster's Avatar
Lyonmaster
Cruising
yes the locks are in the door arm rest, but the power lock switch is accessible with a hanger. However i spent an hour trying to pull the switch up. Every time i just couldn't get it high enough and the angle of the window prevented me from making a straight upward pull.
My T-tops are tight, and have new weather stripping, but when i decided to give it a try, the handle moved. So i kept at it until it finally popped open. I would suggest not wearing any rings or a watch, i removed mine. And use the heel of your palm to spread the impact over the surface area.
Granted i thought the same thing about pounding on my T-tops, but I'm a long way from home in a Military school. If the MP's had slim jims like they used to (they still do but they wont use them or let you use them) i would have had no issues.
Only reason i have my Mistress here at school is because my wife needs the truck... My girl sits inside the garage well protected, and i hardly ever let her out of my sight when I take her out. The factory alarm still works, and it works very well.
To C3 LOCKED !!! Help!!!
