Master cylinder viewing windows?!?
Old Sep 26, 2011 | 01:39 PM
Carlos840's Avatar
Carlos840
Originally Posted by Mike Ward
Thanks-
I went through the joy of getting an older N. Am spec motorcycle through the German TUeV system, they tried the mandatory retrofit stuff too. I eventually demonstrated that they were not following their own rules about a vehicle needing only to comply with the regs in force at the time of manufacture and not today's regs. I pointed out another motorcycle that was already registered and approved that did not comply with one of the specs they were pushing. Turns out it belonged to the examiners boss
Nice!
What would you do in my position?
Whats your view on glass windows? Safe or not?
Old Sep 26, 2011 | 02:05 PM
MelWff's Avatar
MelWff
Have you tried contacting this group
http://www.belgiancorvetteclub.be
Old Sep 26, 2011 | 02:06 PM
Mike Ward's Avatar
Mike Ward
Sounds like you're wasting your time by fighting the issue as you are 'alone'. The present M/C with the bubba windows is a disaster waiting to happen IMHO and demonstrates how bureaucracy can overwhelm common sense. The modification that they've forced you to do has now induced a dangerous leak where one could have not existed before. If people are too ignorant to inspect brake fluid levels 'the old fashioned way' why would they be more attentive with a see-through M/C especially on yours where it's not even see-through? I'd like to see some study that demonstrates an improvement in safety. Canada got saddled with DLRs based on some faulty half-assed study done in Sweden. There has been NO measurable decrease in day-time safety but a measurable decrease in after-dark safety because people forget to turn their main beams on at dusk and are driving with no tail lights.............
if it were me, I'd install the windowed version just for inspection day and put a much safer unmodified version for the remainder of the year.
Maybe glue some phony windows on an unmodified M/C showing a 'fluid line' halfway up? Plead ignorance of you get caught
Old Sep 27, 2011 | 06:26 PM
corvetteload's Avatar
corvetteload
Originally Posted by Carlos840
I like the thinking but i think it would look to "home made" to pass the inspection! I really think the only solution is to sort out the existing windows!
Cars are meant to be stock in this country, you cant just "build your own" like you guys do!
Nothing looks more homemade than those "windows" now, anything other would be a step up!!!!!!
Old Nov 4, 2011 | 11:33 AM
dembo's Avatar
dembo
Carlos, I missed this thread.
I must say I’ve never seen a +25 year old Corvette registered with ‘normal’ plates on which the master cylinder was altered .
There’s also a contradiction as you are not allowed to alter ‘stock’ parts and there’s no alternative. So drive the car without a master cylinder then?
I also think a car has to conform to legislation that was valid at the time of your build year.
The only stories I have heard are non folding mirrors (like the sport mirrors) and no E mark on the seat belts as a reason not to homologate the car.
Did you inform in a different inspection station? Did you check in to the ‘eenmalige type goedkeuring’?
Or did you get it resolved?
@ Mike, it's the same reaon why stainless steel brake lines (from frame to caliper) are not allowed here, the inspectors can't 'see' if the hose is failing with the SS jacket, although the SS ones MIGHT be better then the rubber ones.
Nick
Old Nov 4, 2011 | 07:39 PM
milo30's Avatar
milo30
Why not just change out the master cylinder with a newer style plastic one that is see through and forget about it?
Old Nov 5, 2011 | 09:19 AM
Carlos840's Avatar
Carlos840
Nick
I havent done anything about it yet, looking into it, havent decided yet if i want to replace the windows or change the master cylinder for a new one and hope they dont say anything!
