I think I got mine from Corvette centeral.It fit pretty decent.Same year as yours.Also didn't any shims.Had to bend the lower tabs down for the radiator to fit.
I didn't have a great introduction to Coffman either in this thread. Just because it's made in america doesn't mean a damn thing.
Had a read of your thread. thanks
Its sad that parts can be so far out. Obviously Tolerances are fairly loose.
The core support looks very good generally but.
. The lower mount nuts are 1/4" offset - Will need to enlarge the hole in lower frame
. One of the side mount nuts is 1/4" too high - Needed to modify the hole in the guard bracket to get it to fit.
Also just noticed as you mentioned the core support is not drilled for any of the seals.
Did you just rely on the double sided tape for the seals between the the core and the radiator. ?
Also what about the hood seal, did you glue that on or drill for clips. ?
Craig
Ah you find my other thread about the seals, I was going to mention that in my previous reply. Yes, the PIF holes were not there like I thought they should have been, but again I had an 18" support before with the PIF and switched to the 26". So while I didn't have a stock 26" to compare to, everything I looked at led me to believe that there should have been PIF holes in it. Maybe someone else can chime in on that one. So I just relied on the doublesided tape and the pressure from the radiator to keep it in place, no problems so far.
As for the hood seal, I just used the same weatherstrip glue when I put it on.
