Hi, I'm having some trouble getting my hood to close easily. the passenger side latch goes in easy, but the drivers side seems to get stuck, and I've had to use a screw driver to manually slide the lever under the hood. Once closed, the under dash hood release works well. Any suggestions on this?
Check manually the motion of the slide latch and use some white grease on it. Also try to look at the alignment of the hood pin cone to the hood latch. Sounds like there is an alignment issue of one or the other. Best work on it because sooner or later the inside level will not release the latches and the you have a PIA.
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Originally Posted by ClassicG
Thanks for the help on this. Thats pretty scary though if its really stuck. What do u do if it wont open withe hand release?
You can rig a pull cord to access from under the car in the event you can't open it with the hand release. I know several people that have done this...just in case. haha
Does the release mechanism on the hood latch not work? The cone of the assembly has a slot in it where you can use a screwdriver to increase or decrease the tension on the spring for the closure. On the hood the latch assembly has a curved area that will close around the hood pin. It may be that their is too much pressure from the spring to the flat part that does not allow the curved area to release properly.
Look inside the wiper tray directly behind the latches and there are two plugs you can knock out and get a small screw driver through to push the latch open. Or with a lot of monkey dexterity you can get to the latches from the bottom.
Yes, there is a tab that is to be pushed on to release completly... On my '76 I don't have the knock outs or "cut out".. but the tab is still there....
