Headlights
Old Oct 7, 2011 | 12:33 PM
MAC79's Avatar
MAC79
2nd Gear
Default Headlights
I have a 79 c3. My headlights open but the drivers does not close. Anyideas why or where to start?
Old Oct 7, 2011 | 12:44 PM
MelWff's Avatar
MelWff
Check the vacuum lines going to the headlight actuator.
Old Oct 7, 2011 | 01:10 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
My passenger side does that intermitently. I go out and slightly lift on the light assembly and it goes down. It does it so infrequent, I've just been dealing with it but my initial thought is that it may be a stop screw/bolt adjustment.
Old Oct 7, 2011 | 08:07 PM
MAC79's Avatar
MAC79
2nd Gear
Thanks for the ideas. I'll let you know what I find.
Old Oct 7, 2011 | 08:38 PM
Peterbuilt's Avatar
Peterbuilt
Click here to check each component:
http://www.corvette-101.com/vacuum.htm
There is a Sticky up top for more information.
I agree! The seals seem to be the main problem.
Old Oct 7, 2011 | 08:39 PM
Tim H's Avatar
Tim H
I got under the car with an oil can and oiled everything that moved and my headlights work well now.
Once they are opened the springs keep them open not the vacuum, you can grab the spot where the 4 springs are hooked up and pull it and the light will close once the vacuum is released.
Old Oct 7, 2011 | 08:40 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
do what i did...
Old Oct 8, 2011 | 11:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Vacuum relay for driver's side headlight.
To Headlights
