The buck stops here
Old Oct 7, 2011 | 09:03 PM
68vetteman's Avatar
68vetteman
Default The buck stops here
I'm hoping someone with engine experience can help. I have a 383 with a comp cam 270/275 duration .495/.502 lift. The engine runs great but if I let off of the throttle I feel a bucking from the engine. It stops if I give it gas. I have a 700 double pumper carb that I re-jetted the mains 2 sizes larger because it was running lean. Is this a carb problem (idle mixture too lean) or is this from the roller cam? Idles at 1000 RPM warm.
Thanks 68 Vetteman
