M21 over M20 / WHY?
Old Oct 9, 2011 | 04:54 PM
dmayhew's Avatar
dmayhew
Default M21 over M20 / WHY?
What would be the reason or reasons that someone would order the
M21 Close Ratio Muncie over the M20 Wide Ratio,
I understand the difference in the gear ratios in the trans, but what would someone be looking to get by selecting the M21?
David
Old Oct 9, 2011 | 05:09 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Can't wait to see the old drag racers chime in here. Of course, who the heck is power shifting and slamming gears with a 4 speed these days. I am sure it has everything to do with getting into 2nd gear faster and not dropping too much rpm.
Old Oct 9, 2011 | 05:21 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
David
M21 is the close ratio box (versus the M20). Given how a Corvette is a sports car the M21 (or M22) is preferable out on a road course where the RPMs can be kept closer during shifts (up or down). The M20 is preferable on a drag strip due to the lower first gear (and torque multiplication) to get the car moving off the line.
Old Oct 9, 2011 | 05:23 PM
Mike Ward's Avatar
Mike Ward
Simple as that.
Old Oct 9, 2011 | 05:35 PM
joewill's Avatar
joewill
The regular 4-speed M-20 has ratios of 2.52:1, 1.88:1, 1.47:1 and 1:1. The M-21 close ratio and M-22 close ratio heavy duty ratios are: 2.2:1, 1.64:1, 1.27:1, and 1:1.
a m21 has a lower 1st gear and will bog more if you have a 3.08 rear or similar.
I have a m21 sitting in my cabinet in my garage, but I don't use it since my rear end is a 2.72. If I did use it I bet I could do 75 in 1st gear. plus I would accelerate the wear on my clutch at the stoplight.
the M21 is better for the Roundy-round track crowd if you want your car set up to torque peak about mid way thru 2nd into 3rd gear.
its the closeness of 2nd and 3rd gear that makes these trans beneficial for those that need it.
the lower 1st gear and the more even spread makes the M20 more streetable.
it is almost always more practical to have a M20 for the street.
the M20 is just as durable as the M21.. it's the M22 with its straighter cut gears that make the M22 more of a heavy duty tranny.
Old Oct 9, 2011 | 05:38 PM
Ganey's Avatar
Ganey
The purpose of a close ratio is to stay in the upper part of the power band for racing. A drag car would have low rear gears so a 2.20 first is not a disadvantage.
Old Oct 9, 2011 | 05:46 PM
parkerracing's Avatar
parkerracing
If you had a 3.55 or lower (numericly) rear end, you'd probably be happier with the M20. If you have a 3.70 or higher (especially with an LT1 or BB) you'd want the M21 or 2. I'm sure there will be some discussion as to where I put the split in the ratios, but that's part of the fun./:\
Old Oct 9, 2011 | 05:49 PM
dmayhew's Avatar
dmayhew
Thanks to all
These replies are a big help.
I have a friend that I see once a year at a major local car show,
He has a 71 LT-1 Vert with M21 and 3:55
My 71 LT-1 is a M20 with 3:70
He was asking me about the difference yesterday and I could not give a good answer, But now I can
David
Old Oct 9, 2011 | 06:43 PM
mstanton's Avatar
mstanton
Thnaks to all
David
Just for reference, for an LT-1 with M20, 3.55 was the standard rear ratio. For LT-1 with M21, 3.70 was standard. Your LT-1 has the standard M20 with an optional "performance" ratio and his LT-1 has the optional M21 with an optional "economy" rear ratio. As a comparison the base 270hp came with M20 and 3.36 rear standard..
Old Oct 9, 2011 | 07:32 PM
UberLegend's Avatar
UberLegend
M21 when you need to stay in the upper torque curve.
To M21 over M20 / WHY?
