Leather Dye for Seats?
Old Oct 10, 2011 | 09:49 AM
AdamMeh's Avatar
AdamMeh
Default Leather Dye for Seats?
If I wanted to dye a small portion of a leather seat to "repair" the normal wear marks from getting in and out of a car could any of you suggest a brand / method for me?
The leather is not cracked or worn through, just the color has been worn off (side bolster on drivers side).
If any of you have done this, are the results something you were happy with?
Thank you in advance for any advice,
Adam
Old Oct 10, 2011 | 11:24 AM
Sully1882's Avatar
Sully1882
SEM for dying your interior parts. I did this a few years back and just like with the exterior prep is everything to insure a quality result. Clean scrub clean tape off and spray in multiple light coats.
good luck,
Sully
Old Oct 10, 2011 | 11:35 AM
AdamMeh's Avatar
AdamMeh
I'll check them out right now. Thanks for that.
I have an airbrush - would that be the best thing to spray with? I'm guessing I will be dealing with very small amounts of the dye and as you said light coats.
Thanks again,
Adam
Old Oct 10, 2011 | 12:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by AdamMeh
...I have an airbrush - would that be the best thing to spray with?...
Air brush might be maxed out. I used a Craftsman Touch Up gun and a regular compressor.
Old Oct 10, 2011 | 12:29 PM
Sully1882's Avatar
Sully1882
if you are doing a color change it's more tedious but still done and done well. If you are just redoing your parts in the same color even better. Buy enough for one batch so you can do it all in one bang and that way there is no variance in the color mix. If you are dealing with black.... go to autozone and buy 8 cans of the vinyl dye and go to work on your parts. Black makes it all easier and the one they have there works great. I think it may be duplicolor in an aerosol can.
hth,
Sully
Old Oct 10, 2011 | 12:48 PM
AdamMeh's Avatar
AdamMeh
I have a compressor and paint guns as well from my past car projects (painted my last Challenger myself), so I will plan to use that.
I'm just touching up the side bolster panel of the drivers seat - it's a light graphite color. I am looking for it to be a nice job as this is in a car I'm selling and want to do it right and add to the value of the car.
Thanks for your advice
Old Oct 10, 2011 | 02:19 PM
AdamMeh's Avatar
AdamMeh
Found the SEM stuff locally at a Auto Body Supply. On my way to get it.
Thanks again!
Adam
Old Oct 10, 2011 | 09:44 PM
stock76's Avatar
stock76
Color-matched interior dye (like the SEM products) will work fine on leather. If the spot is not large you can use a small artists brush to touch up the worn area.
A number of Corvette parts vendors sell the color matched dyes in spray cans and larger quart cans.
Do a "test" area first though. Not all the dyes from different Corvette parts vendors will be exactly the same shade as your interior. Should be pretty close though.
If there is a Tandy Leather company in your town, they sell a product called Eco-Finish you can use to seal the area you touched up to make the repair more durable.
Old Oct 10, 2011 | 10:05 PM
AdamMeh's Avatar
AdamMeh
I used 600 grit then 1000 grit wet/dry paper on it (lightly) to smooth out the problem area. I then used SEM Leather Prep followed by the dye and it really turned out well. A very, very close color match
I will run over to the Tandy store tomorrow and pick up some of the Eco-Finish. Think I'll let the dye dry for a day or so then use that.
Very happy with the results!
Thank you!
Adam
To Leather Dye for Seats?
