73' L-82 starting issues
Old Oct 10, 2011 | 11:29 PM
grahambb's Avatar
grahambb
Default 73' L-82 starting issues
I have a 73' L-82 that will not start when cold. It will start with starter fluid very easily and after being run for a short period of time (2 min) will start without starter fluid.
procedures tried on seperate occasions: (seperate being more than 24 hours apart to allow for complete cold engine)
1. turn key (zero throttle)
2. turn key (with throttle full open)
3. cold starting as owners manual says: pump of the gas and a slow return to zero throttle, turn key.
4. 1 pump of gas, turn key (with throttle full open)
3. 2 pumps of throttle, turn key.
4. 3 pumps of throttle, turn key.
5. 4 pumps of throttle, turn key.
6. 2 pumps of throttle, turn key, wait 5-7 min, 1 pump of throttle (this worked once without fluid)
7. same as 5. with 2 pumps after 5-7 min.
engine idles smooth with no backfire or irregularity. when the car sits between occasions the throttle sticks at about 25% throttle, more pressure is applied and it breaks free and the throttle then has smooth operation. any help would be greatly appreciated.
bg
Old Oct 11, 2011 | 10:08 AM
MelWff's Avatar
MelWff
You could have either fuel drainback which can be corrected by installing a fuel filter in the Quadrajet with antidrainback valve, NAPA has them. The other possibility is the plugs on the bottom of the carburetor are leaking.
Here is a link to an article.
http://forums.corvetteforum.com/c3-t...rain-back.html
Old Oct 11, 2011 | 10:37 AM
Mike Ward's Avatar
Mike Ward
Is your choke and high idle working correctly? If the throttle is sticking part way open, get it fixed before you run into somebody.
Old Oct 12, 2011 | 11:58 PM
grahambb's Avatar
grahambb
I will see about a check valve first to try and fix the cold start issue. I appreciate the link Melwff, im sure one of those 3 solutions will work.
I am new to the carb scene so pardon my lack of knowledge. I believe the choke is working correctly, engine speed is high for 15 min or so until the temp is up, then the rpm's slow. Is there another means of determining a proper high idle/ choke function? The throttle only sticks on the first closed to open stroke after having sat overnight. It has not stuck on the open to closed yet. Is this just an issue of the carb needing cleaning?
thanks,
bg
To 73' L-82 starting issues
